Question about Nokia 6288 Cellular Phone
Nokia so annoying please need help
Every time i turn my nokia back on all the wallpapers and ring tone completely reset. please help me
    Sergeant:
  • 218 Answers
If u will remove ur memory card the problem will always rise u must simply copy ur wallpaper, ur ringtone, ur themes to phone memory and then remove memory card then set ur wallpaper, ur ringtone, ur theme. switch it of then insert memory card and then turn it on u will find that they are not reseted again. and please rate this solution. Have a good day
Posted on May 09, 2008
Why my nokia C3 doesnt ring accordingly although i set the ring tone already?its only vibrate.i'm not using silent mode.
I can imagine it how annoying it would be to you to see your cell vibrating instead of playing your favorite ring tone. Most probably it could be because of incorrect Profile configuration. It is possible to make your phone vibrate in almost every profile so we will assume that it is the reason for your problem too. Do the following and check some parameters as described.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Jun 04, 2011 | Nokia C3 Cell Phone
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
Nokia 2630 cellphone ring tones and walllpaper pics lost
hi,
yes ,there s a solution there but you will spend a little amount of money...in reseeting phone like 2630 ,all you files like contacts ,themes ,ring tones ,games ,wallpapers will be deleted ...to get it back ,go to nokia care center or even to a small cellphone repair shop to flash your phone in version 5.61 or 6.82 to bring back all your default files like wallpapers and even ring tones..
i hope it will hel you ,thanks for rusting fixya ..
br ,
fullbar_28 from the PHILLIPPINES
Jun 16, 2010 | Nokia 2630 Cellular Phone
I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 23, 2010 | Nokia 1661 Cell Phone
Nokia 1661 my phone not ringing why ?
Mar 22, 2010 | Nokia 1661 Cell Phone
I had purchase a new nokia 1650 wont ring or vibrate
just fomat your phone first then try to change your tone settings
Mar 11, 2010 | Nokia 1650 Cell Phone
Lost all tones and wallpapers
format the phone you will get all the tones which the nokia company givews while manufacture
Apr 09, 2009 | Nokia 6500 Slide Cellular Phone
Ring tone wont load
There might be something wrong with that file.
Jan 17, 2009 | Nokia 5500 Sport Cellular Phone
Ring tones, Thems and wall Paper
Call your Phone provider or goto thier website and chat with tech support they should be able to send your files back to your phone
Dec 27, 2008 | Sony Ericsson W200i Cellular Phone
Message Tone
in profile settings turn off warning tones
Dec 03, 2007 | Nokia 1100
Nokia 6288 Cellular Phone Logo
90 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
