Question about ViewSonic VIESONIC 17" BLACK CRT 1280X10 Monitor
USED TO HAVE AUDIO, MOVED MONITOR, NOW NO AUDIO
    Genius:
  • 1,970 Answers
Mcdevito75 here, Check all connections at the back of the computer, Hope this helps.. Also check the volume control at your keyboard and at the monitor tray, lower right side of screen.
Posted on Jul 20, 2010
Moved to a new computer and lost audio
Download or use motherboard disc drivers Audio drivers install,download if no disc by using make and modle
Dec 27, 2013 | Acer P216HV Black 21.5" Widescreen LCD...
When I turned on my monitor this monring it is making a loud clicking noise every couple of seconds.
I was having this same problem with my monitor for days and it was driving me nuts, and being in IT not being able to solve it was even worse. My Viewsonic is a VA2232wm with built in speakers, I muted the speakers on the computer and using the control buttons on the monitor with no luck, it was still clicking. I move my laptop to and from my desk all the time and everything goes to the monitor via a USB docking station except for the audio. The audio cable I have to plug in separately. In my haste, the last time I connected the audio cable to my laptop, I put it in the microphone jack instead of the speaker jack. Once I moved it to the right jack, the problem was solved. Not sure if this will resolve your problem or not, but I hope it helps.
Jan 17, 2011 | ViewSonic VA1912wb Monitor
Monitor speakers wont produce sound
seems a silly question but I have to ask, has the monitor ever produced sound? Also have any leads been moved recently?
If the computer is well used it's worth checking that the audio lead from the monitor is in the right 'hole' in the pc, easiest way to do this is play something and then move it from hole to hole until you hear noise.
Finally it is (remotely) possible that its a driver issue, check in computer management looking for any question marks in device manager, if it is a missing or corrupt driver then you can get a fresh and up to date driver from the manufacturers support site (check google for this)
Its worth trying an updated driver anyway, no harm in getting a newer driver anyway.
Oct 29, 2010 | Hansol H750 17" LCD Monitor
I got my computer 10 months ago and everything was working then my volume stop working. I could only hear stuff if i used my headphone and that went on for about 3months . Then i moved the computer to...
You will have to check for a possible loose connecction in either the earphone socket or the audio amplifier within the main board - audio section.
It is possible that while using earphone jacks the socket can be damaged over a period of time , there is a cut off of main speaker when headphone is used and releases when taken out.
So check here for audio , if not solder the Audio IC or connectors.
Sep 16, 2010 | HP W2338H Monitor
I lost my plug for audio ina move. what do i need
You just need audio cable with mini-stereo phone plug at both ends, try RADIO SHACK.
http://s807.photobucket.com/home/budm/allalbums
Jun 05, 2010 | Hannspree HC-194D 19" LCD Monitor
I installed my tascam mk2.under Cubase LE4. Midi tracks work good.In "set-up devices" I see the Tascam inputs and outputs.Monitor VU-meter is not moving in this audio track and consequently there is no...
Have you clicked the little "monitor" icon (looks like a speaker) on the armed audio track so that it goes orange? Once on, you should see a signal on the VU meter (assuming the line in has a good signal etc). Once recorded, turn the monitor off again to listen to the track with all the others.
Jan 26, 2010 | Tascam US-144 Sound Card
No Sound. We moved the computer and now no sound.
Try checking to see to make sure that the audio jacks are plugged into the right ports. Also, check to make sure that nothing is muted, and that volume is up ( I've actually went for sound without a day after moving my computer because I forgot I had muted and turned my volume all the way down the day before xD )
Anyway, I hope this helps, and let me know if it doesn't.
Oh, and one last thing, make sure that your speakers are set as the primary output devices. If you have 3rd party audio drivers, sometimes you have to set what audio output is going through.
Oct 17, 2009 | Samsung SyncMaster 172 W 17" LCD Monitor
How do you connect Audio Buddy to computer
You probably connect the Audio Buddy via a USB or firewire cable. I use both types of audio interfaces. Your mac will sense which bus has audio. Go to System Preferences panel and select sound. Select input. You should see your Audio Buddy listed if it is connected properly. You can set levels from this panel and test the device by looking at the two level meters. Speak into the mic; the level meters should move from left to right. Go to the output panel and chose your monitoring device. I prefer the built-in speakers, but you could also connect your monitor to the USB interface or even the Audio Buddy. If I need better quality monitoring I plug a mini cable into the earphone jack and use a desktop speaker. Don't try to use that headphone jack for anything but monitoring - the quality is not great. If the Audio Buddy software requires that you select an input source, always use USB, never line or built-in mic. Another way to capture audio from an Audio Buddy or similar device is to use Wiretap Studio Pro or Roxio CD Spin Doctor for audio capture. I use both.
Dec 03, 2008 | M-Audio M Audio Audio Buddy Microphone
No sound from the monitor or playback
check out where your monitors are receiving their audio from.is it from the tascam or the onboard or audio another interface.first choose an output for your sound,if you using the tascam as an output for your sound connect your monitors to the phones input in front and use the mono mix knob to swap between audio coming from your usb or computer.if you want to hear from your mic or guitar move knob to usb if you want to hear from computer as in playbck move it to computer.
Nov 21, 2008 | Tascam US-144 Sound Card
I have 2 identical monitors that i use for my studio
They are sitting right next to each other?
sometimes you have to space electronic out, due to there out put... if they are really close to each other try moving one and see what happens.
hope this helps
Jun 05, 2008 | X2Gen MG19MY 19" LCD Monitor
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
See all ViewSonic VIESONIC 17" BLACK CRT 1280X10 Monitor Questions
ViewSonic VIESONIC 17" BLACK CRT 1280X10 Monitor Logo
24 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
