Question about Nikon COOLPIX P5100 Digital Camera
Nikon P5100 memory card will not lock into place
pishta68
  • 593 Answers
SOURCE: Nikon Coolpix P5100 settings
Olympus cameras have an "all reset" function that can be toggled on or off in the menu. If "on", all settings are restored to default on boot up, if "off" then the last setting are kept on boot up. If the settings are supposed to be kept be design,but are not, then the capacitor or small battery on the main board needs to be replaced. Not user replaceable, usually soldered on or socketed but no simple access.
Posted on Dec 06, 2008
SOURCE: Nikon D60 memory card problem. When i turn my
check your sd card, there's a tiny bar on the side that you can "slide" to unlock...
Posted on Aug 24, 2009
  • 10 Answers
SOURCE: The LCD of my Nikon P5100 can not display
You probably have a lose connection on your LCD. Mine was the same. I initially sent it off for repair and it worked fine for about 6 months or so but then started playing up again. Today I took it apart myself to recheck all the connections. I took a series of set-by-step images and once I have sorted them out and written up the instructions I will post it so you can have a go at fixing yours.
Posted on Feb 09, 2010
  • 102366 Answers
SOURCE: "memory card is write protected"?? but it's not the memory card!
It's not the camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 09, 2010
jonniewalker
  • 1031 Answers
SOURCE: my d80 cameras memory card locked automatically when i insert in
it has a write proctect tab on the on the side of the card when its down the card will be locked ,slide it up to remove the lock.hope this helps pls do let me know
Posted on Jun 06, 2010
The battery and the memory card will not eject. Please advise.
What happened? did you drop the camera? did you let it unused for months and months? Can you open the battery chamber/memory card slot cover?
Can you move up the orange battery latch?
Is there any debris in the battery chamber or memory card slot?
did you push in the memory card, so it can jump out?
Please inform, perhaps I can help a little more.
Oct 29, 2013 | Nikon COOLPIX P5100 Digital Camera
Cannot view or download images from memory card on new Toshiba laptop. Was able to do it yesterday then uploaded Nikon Coolpix disc and now it error is indicated. I deleted disc programme but problem
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jul 24, 2012 | Nikon COOLPIX P5100 Digital Camera
Transfer photos to memory card
Press the Playback button (right-pointing triangle). Press the MENU button. Use the multiselector to select "Copy". Select the first option to copy from internal memory to memory card.
Full details are in the "Copy" subsection of the "Playback Options" section (pages 119 and 115 in my copy). If you need a manual, you can download one here.
Oct 16, 2011 | Nikon COOLPIX P5100 Digital Camera
I have taken pictures on the camera memory and cannot find the cable to download unto the computer... Is there any other way of getting those pictures to download?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
May 31, 2011 | Nikon COOLPIX P5100 Digital Camera
HOT TO DELETE ALL PIC ON FROM SD CARD
You can use the "Format Memory Card" option under the "Setup Menu" to delete all images on the Memory Card at a time.
Jan 22, 2011 | Nikon COOLPIX P5100 Digital Camera
My nikon camera says "Memory
Remove memory card from camera and slide lock in memory card (check photo).
Dec 02, 2010 | Nikon View DX (25243)
Memory card won't stay in the slot, won't read.
service camera at Nikon. mechanical SD card lock failure
Nov 24, 2017 | Nikon Coolpix S210 Digital Camera
Apr 24, 2009 | Nikon COOLPIX P5100 Digital Camera
Sd card won't stay in the slot of my nikon coolpix S210
See fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
Jan 16, 2009 | Nikon Coolpix S210 Digital Camera
Coolpix l5 - SD card won't seat
The Nikon are very good about placing a sd symbol on the door of the memory compartment. The trick is to align the dog ear side of the memory stick with the picture on the door the push down until the stick bottoms out in the slot it should then lock in to place. Conversely to remove it push down again until it un locks.
Dec 07, 2008 | Nikon COOLPIX L5 Digital Camera
Nikon COOLPIX P5100 Digital Camera Logo
44 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
