Question about Garden
Just took my 3.5 hp briggs & stratton engine apart. How do the internal gears go back in. Basically how do I reassemble them
There will be a small dimple on the larger cam gear and also one on the crankshaft gear just line the two up face to face
Posted on Jul 20, 2010
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
Jul 17, 2014 | Briggs & Stratton Briggs Stratton Intek V...
My briggs and stratton 18 hp vanguard model 356447 will not start just back fires through the carb. I have good comprssion and spark at both plugs. I replaced the flywheel key as thought the backfireing...
check intake valves for proper seating. If the valves do not close completely it will allow the engine to backfire thru the carb. Another possibility is internal timing caused by the misalignment of the timing gears between the crankshaft and cam gears.
Oct 29, 2013 | Briggs & Stratton Briggs Stratton Intek V...
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
Sep 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 19.5 HP engine
just had the same problem found the internal jets in the carb plugged took it apart and soaked it for a couple days runs great now
Apr 22, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do you reconnect the two throttle rods on a Briggs 136212 006
Go to this site or type into search
briggs &strattone ngine
bsppwebtools.com/data/manuals/1678_0esfw.pdf
Sep 12, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Engine seems to flood out when increasing speed and dies
If it starts lightly smoking black smoke at high RPM it is flooding or getting too much fuel. The float is leaking you may have not set the float height correctly when you put that carb back together. Or the needle and set could be bad.
Sep 11, 2009 | Briggs & Stratton Garden
Back firing, load engine noise, engine skip
Could use more info but here are some things u can check--Plug wire grounding to block, old spark plug--check head bolts for correct torque--carb adjustment or jet plugged-governor linkage not hooked up or improper adjustment of governor--if these are good then it could be internal--bad valves and valve adjustment--timing gears
Jul 18, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
52 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
