Question about Uniden BC340CRS Base Scanner
I cant program my new scanner..
I press down the E and nothing happens except it makes the clock flash.well got the time to stop flashing but now i press E and nothing happens..Dang i am an old lady and need help..I have the numbers to enter but nothing happens...Does this make any sense at all??
  • Anonymous Dec 20, 2008
    Ican not program the uniden bc340crs base scanner.
  • meredithnorl Feb 01, 2009
    cant program
    Problem Solver:
  • 5 Answers
To program your channels. say start with #1 push prgm,type in the frequency number and press enter. repeat for each channel/ frequency
Posted on Dec 27, 2008
I have a GE space saver microwave, JVM1653SH02, stopped working.
Sorry but at the price of repairs I would pitch .
Jan 19, 2015 | GE Kitchen Ranges
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
Dec 22, 2013 | Zanussi FS1455W Front Load Washer
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
I have Mr Coffee APX33; I do not know how to set the coffeemaker to turn on automatically. I do not have the manual. Hope you can help. Thanks! Larry
First you have to make sure to set the clock for the correct current time:
Press down and hold the SET button. Then alternately press the UP and DOWN buttons (indicated by arrows), until you reach the current time, then release the SET button. (there is a PM indicator on screen but not an AM indicator - if you don't see the PM you are at AM)
To set the time for the brew to start in the future:
Press and release the MODE button once and the Delay Brew Clock picture will start flashing on the screen.
While the Clock picture is flashing - hold down the SET button while you use the UP and DOWN arrow buttons to set the desired brew time (you can hold down an arrow button to get there faster). Release the SET button and now that brew time is programmed. (After a few seconds the clock picture will disappear but the future brew time is programmed.)
To activate the delayed brew:
Press and release the MODE button once. The Clock picture will be flashing and the time shown will be the time that you previously set for the future brew). While the Clock picture is flashing - press and release the BREW button. The Clock picture will remain on steady. The BREW light will not come on until the time in the future that you have programmed.
Pretty confusing - but it does work. Just remember that if you see the Clock picture on steady - the machine will come on at the time you have set in.
If you want to use the machine earlier - while the Clock picture is steady - you just press the BREW button and it will brew.
If the Clock picture is steady but you want to cancel the automatic future brew - just press the BREW button twice. (This turns it on and then off and cancels the future brew).
I can send a copy of the manual if you like. Lennyg678@aol
Sep 17, 2010 | Mr. Coffee APX33 Coffee Maker
Ive just moved into a flat with a servis 7kg 1500AA washing machine and i have no instructions for it. when i press the on button the yellow light above another symbol flashes and nothing happens. ive...
Hi. Set the dial to reset (12 o-clock position) then push button second from right. Now set to program required and press button again. Should work now. Needs resetting every time, this is normal. Hope it works for you.
Sep 10, 2010 | Washing Machines
The clock is flashing all zeros - cant set it
Press: Stop cancel
Press: Clock or Autostart (depending on model)
Set time
Press clock or autostart.
Should have the time set......
If this is too generic pleae provide a make and model and I wil see what the manual says verbatim.
Kelly
Aug 21, 2010 | Microwave Ovens
Indesit WIXL143 stops part way through program
Technical Jargon error F02 Motor jammed / tacho detached: check motor & module connections
Basically the strong possibility of a faulty Motor
Mar 21, 2010 | Washing Machines
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
No setting instructions.
Atomic clocks are the wave of the future because of their precision. While it takes a scientist to fully understand how these clocks actually work, the general public is primarily interested in their accuracy, rather than their construction. A major benefit to atomic clocks is that they serve as the main standard for calculating time internationally. While each version of atomic clock may have minor differences, for the most part, they are set in the same way.
1. Remove the battery cover on the back of the clock using the correct screwdriver (if one is required). Be careful not to break the cover or lose any screws in the process. Insert the required number and type of batteries into the clock. Most atomic clocks take two AA batteries. Make sure the batteries are positioned with the right polarity in place, and that the clock is functioning, before replacing the battery cover. Place the cover back into its original position and screw any necessary pieces back into place to secure the cover and protect the batteries from springing free.
2. Enter the program mode of the clock by holding down the appropriate button. In most cases, the button will be clearly marked "Set." If not, refer to the clock's instructions to find out which button fulfills that function.
3. Push the button down until the clock flashes its default time zone setting of --5EST. It is now ready to program each function separately as described in the steps below. If for some reason the clock does not respond as outlined, refer to the instructions provided with it for troubleshooting guidance.
4. Press the + button to select the right time zone from the 13 international options provided. The default setting of --5EST (Eastern Time), should appear first, followed by --6 CST (Central Time), -7MST (Mountain Time), -8PST (Pacific Time), -9ALA (Alaskan Time), -10HAW (Hawaiian Time), -11, -12, GMT (Greenwich Mean Time), -1, -2, -3 and --4ATL (Atlantic Time). Then push the "Set" button down again to confirm the time-zone setting you have chosen. Push down the "Set" button again and hold until the selected time zone flashes.
5. Press the "Set" button down two more times to establish the default language setting. Press the + button down to select English, French or Spanish. Then push the "Set" button down again to confirm the language setting.
6. Push down the "Set" button again and hold it until the time zone flashes. Then press the button down three more times until the time 12:00 flashes. Press the + button down to select the hour at the time of the clock's setting. Make sure the hour is set appropriately to AM or PM. Then push the "Set" button down once more to confirm the hour setting.
7. Push the "Set" button again and hold until the time zone flashes. Then press the "Set" button four more times until 00 flashes. Press the + button down again to select the minutes at the moment of setting. Push the "Set" button once more to confirm the minute setting.
8. Push the "Set" button again and hold until the time zone flashes. Then press the "Set" button five more times until the default year flashes. Press the + button down. Toggle through the settings until the appropriate year is reached. Then press the "Set" button down to confirm the year.
9. Push the "Set" button again and hold until the time zone flashes. Then press the "Set" button six more times until the default month of January is reached. Toggle through until you reach the right month. Then press the "Set" button down to confirm the month.
10. Push the "Set" button again and hold until the time zone flashes. Then press the "Set" button seven more times until the default date of 1 is reached. Toggle through until you reach the right date. Then press the "Set" button down to confirm the date.
11. Push the "Set" button again and hold until the time zone flashes. Then press the "Set" button eight more times until the default setting of Sunday is found. Toggle through until you reach the right weekday. Then press the "Set" button down to confirm the weekday.
Hope this helps......best wishes.
Aug 28, 2009 | GPS
Uniden BC340CRS Base Scanner Logo
106 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
