Question about SanDisk Sansa e260 MP3 Player
E260 is not reconize by any computer
My son sansa e260 is working but when he is plug to a computer, then the sansa says: connected but all the computer in my house are not able to reconize the sansa. That sansa works well before and now my son cannot download nothing on the device. And I dont know if something is broken on that sansa or it is just a trick to do. Thanks for your help
  • 5 more comments
  • viargu Sep 23, 2008
    sansa C250 was earlier working smothly with my desktop XP . But after reformatting and reloading XP and upgraded with SP3 it is only viewing sannsa but not able to access and load media into Snsa. I am not able to see the music/photo directories.
  • Anonymous Sep 26, 2008
    First time I plugged it in, it attempted to do the "Found new hardware"
    procedure. It failed, "A problem occurred..." I've tried uninstalling
    and reinstalling the device drivers and nothing changed. Device says "Connected"
  • nichole18 Oct 01, 2008
    Just last week I put songs from my computer to my sansa and now this week my computer doesn't recongize that anything is plugged in. The mp3 player says connected and it charges but the computer doesn't show that anything is plugged in.
  • ayupan_53 Mar 08, 2009
    i have the same problem, but my is refurbish.
  • sdfa Apr 06, 2009
    my computer won't reconize it
  • kittyma869 Apr 11, 2009
    i haave the same prob. but when mines dose finally show up it is under e250!!!!!!!!!! please help me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • chemicall576 May 11, 2010
    my e260 does not show any USB mode option?...is there a way to show it?
  • 758 Answers
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it on the back of your computer...
Should you have any questions..let me know..
P.S.Please rate accordingly...
Thank You
Computerrep
Posted on Apr 22, 2008
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
Cannot get my computer to recognize my sansa e260 player
On your Sansa Go to "Settings" then "System Settings" then "USB Mode," change it to MSC, now try connecting it. If that doesn't work try the other modes just in case.
Hope this helps!
May 01, 2009 | SanDisk Sansa Connect MP3 Player
Jack problem
This unsually indicates a bad connection with the jack. Not the headphone jack, but the connector on the player. My son had that issue so I ended up opening the unit up and resoldering the connector to the circuit board. Don't recommend doing that. You'll need to have a technician do that or if it's still under warranty take it in.
Apr 16, 2009 | SanDisk Sansa e260 MP3 Player
My computer will not reconize my sansa ipod
I had the same problem. But then I figured it out. If you are using Windows Media Player, and it doesn't reconize it, then the VERSION does not reconize it.
The other computers might have a different version.
My computer has a version 10 and it works. Go to http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx and download a different version. (There is no harm or virus)
Apr 17, 2008 | SanDisk Sansa e260 MP3 Player
Dead Player
Hmmm...the MP3 parts shouldn't have lined up with the iPod dock. Check that area for damage in case your son accidentally forced it. Otherwise, hold the power button for 15 seconds. That can occasionally jump-start my player, and it turns the player off even if it is frozen.
Jan 22, 2008 | SanDisk Sansa e260 MP3 Player
IT wont turn on
tyr holding both the power button and the play button for 20seconds at the sametime
Dec 28, 2007 | SanDisk Sansa e260 MP3 Player
HELP WITH SANSA E260
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 02, 2007 | SanDisk Sansa e200 MP3 Player
Sansa help
Change the USB mode by going onto your MP3 and go to settings change it from MTB to the other mode then try to coneect it again.
May 25, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
210 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
