Question about Gateway 4026GZ Notebook
Need to Change WEP Data Encrytion to WPA in Wireless Network Connection Properties
I am having a problem getting a wireless network connection because I believe my Data Encrytions do not match. On my desktop I have it set as WPA but on my laptop it's set as WEP. I wnet into Wireless Network connection and clicked properties and it will not let me manually change this. Please Help!!!!
  • Anonymous Mar 23, 2009
    can you go step by step on how to change wep's
    Scholar:
  • 87 Answers
Hiya, first thing you should check is that your wireless card/usb on your laptop actually supports WPA. I changed to WPA and 3 out of 5 of my laptops could not log on. Took me an age to find out what was wrong. Try changing back to WEP on both units. If they can both log on then see if you can try to borrow a wireless card that you know supports WPA, change back to WPA settings and see if new card works. Don't even assume that new cards/usb's are all WPA compatible. Friends was bought in Nov and isn't able to run WPA.
Posted on Apr 23, 2008
I can't connect the wireless network even it shows that the wireless connection status shows as follows: connection status: connected network duration: going on signal strength: excellent However, the...
Your router's wireless encryption setting (WEP) has been changed.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
May 02, 2011 | Computers & Internet
Suddenly today after working for a couple of years all the lights are on solid and my wireless laptops can not find the router
To connect to your wireless network using Vista's WLAN Autoconfig, follow these steps:
Step 1:
Right-click this icon 5449-001.png at the bottom-right corner of the screen and select Connect to a network.
Step 2:
Select your Wireless Network Name or SSID then click Connect.
NOTE:
If the wireless network name or your SSID is not listed, the SSID Broadcast on the router might be disabled. For instructions on how to connect to the wireless network with the SSID broadcast being disabled, click here.
If the computer is not detecting any signal or is not seeing any wireless network, change the channel of the router. For instructions, click here.
If WEP/WPA is enabled on the router:
Step 3:
Enter your wireless network WEP/WPA Key on the field provided then click Connect.
NOTE: To learn more about WEP/WPA and other Wireless Settings, click here.
NOTE: Make sure Display characters is checked, to display the WEP/WPA key used by the router. You can get the passphrase or network key from the encryption that has been generated (if using WEP network security) from the router's web-based setup page. If you're using WPA network security, the network key is the key for passphrase.
Make sure you enter the wireless network's WEP or WPA key not the Passphrase.
It is also possible to make a wireless connection even if the wireless security is disabled on your router. If you don't see any network SSID from your network list, make sure your wireless adapter/device is ON and your router is in good condition. If your router shows any unstable occurrence, click here.
Related Article:
Configuring File and Printer Sharing Unable to connect to a wireless network using WEP in Windows Vista Windows Vista Articles Listing Encountering Difficulty Connecting a Wireless Computer/s to the Internet when Connected to a Linksys Router Setting-Up the Wireless Settings on a Router Assigning a Static IP Address on a Wired Computer
Nov 06, 2010 | Linksys WRT300N Wireless Router
Setting secured wireless connection
You can enable WEP on your router.
In the address bar of your browser, type 192.168.0.1 to access the setup page of the Dlink router.
By default the username is admin and leave the password blank.
On the Setup page, go to Wireless.
Security Mode should be WEP then click Next.
You can change the WEP KEY 1. Make sure you remember this because you will need to enter this on your wireless computer.
Save the settings.
I hope this helps!
Jul 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
Hama Wireless USB Adapter ''limited connectivity.''
you need to modify the wireless settings on your router. In case, if WPA-PSK security is enabled change it to WEP 64 bit encrytion and than try.
Feb 17, 2010 | Computers & Internet
Windows was unable to find certificate to log on to the network
This type of error message appear when we are trying to connect to the wireless network.
For Windows(xp) perform the following steps:-
a)click on start menu and then go to control panel and then open network connections from there.
b)Under network connections an option for wireless connection exist , right click on that option and then click on properties.
c)Under wireless network connection properties there are three tabs general , wireless network and advanced.
d)Left click on wireless network tab and check the box which says use windows to configure my wireless setting's and click OK at the bottom.
e)Then , Right click again on wireless network connection and click properties and then again click on wireless network tab.
f)At the bottom of the wireless network tab you will have preferred networks and in that small box yo will have list of networks and therefore delete all of them from there including the one you are trying to connect to.
g)On the right hand side of preferred networks you will have ADD click on that option and enter the details of your network manually.
SSID(name of the network)
Network Authentication:-Open if the security is WEP else WPA-Personal.
Encryption:-WEP for wep security TKIP/AES for WPA-PSK.
Network key/Confirm network key:-is the wep key or wpa-psk password.
Untick the box at the bottom that says the key is provided to me automatically.
Click OK at the bottom and close the properties window.
h)Then , Right click again on wireless network connection and then left click on view available wireless network.
i)List of available networks will be there , select the network you use and try connecting to it , it will get connected automatically.
Nov 19, 2009 | Computers & Internet
My ausus eee pc series netbook wont connect to the internet what can ido ?
OK - I just went through 2 hours of madness to finally get this going on mine as well - here's what you need to do.
1. Go to your router settings (security) and if you have WEP enabled, change that to WPA (this is a better security anyway)
Follow this - step by step:
2. double click on your wireless icon (lower right corner of windows) - this will open up the "Wireless Network Connection Status"
3. click "View Wireless Networks" - you'll see all available
4. on the menu items to the left, click on "Change Advanced Settings"
5. pops up the Wireless Network Connection Properties window
6. Click Wireless Networks tab
7. click on your home network, or whichever one you normally connect to
8. when it's highlighted, click "Properties"
9. Make sure that the WEP is NOT selected, and select WPA
10. when you go to connect, it will again ask for your credentials - enter it, it should start checking acquiring network address...and you should get connected.
By the way, I tried updating drivers - restarting, moving closer, blah blah - waste of time. Changing the protocol from WEP to WPA did the trick, but remember you have to do it on the router AND your netbook.
if this helps, shoot me a "positive" on the feedback!!
on your netbook, go into your "view wireless networks" - choose the one that you normally use, for example, your home wireless network
Oct 26, 2009 | ASUS Computers & Internet
Don't know what to change to allow PC to reconize wireless.
If your using Vista: (64bit and cant download the program to clear arp error)
Start > Network > Network and Sharing Center > Manage Wireless Network > Highlight your Wireless connection ( Select Remove) > Add > Then go through the process of finding your wireless connection and you magically got back your protected wireless agian.
Hope this solves it.
Apr 18, 2009 | HP Pavilion dv6000z Notebook
Not prompted for network security key
Sir,
Under 'preffered networks', which can be found on the Wireless networls TAB in advanced settings, you will see your network there. Click on it and then hit properties. Under the 'Association' TAB, you will see network authentication, choose WPA-PSK or WPA, but I will imagine that your key is a Pre-shared key. Enter it there. Data encryption will be TKIP and not AES. Go to connection TAB, and make sure the box is checked in that section. If these steps fail, then you can always change your encryption to WEP. You can do this using a computer which connects to your internet through the WPA key. Once connected on that PC, open up command prompy using the command cmd in the RUN box when you click on the START TAB. A black box will open, simply type ipconfig and look for "default gateway"...it will have a number with a few dots, like this one: 192.168.1.254.....etc. Enter this code into your internet browser search bar, and hit enter. Your internet providers interface will show up, you can find a tab which will have something to do with wireless security, and there you can change the WPA to WEP, with a WEP key of your choice. If you are prompted for a password then you should know it! Sometimes, the usernames can be simply 'admin'. If you manage to change your security to WEP, you can use your laptop!
All the best.
Jan 01, 2009 | Linksys Wireless-G WRT54GS Router...
Wep encryption on WGR614 router
No, WPA is more secure than WEP. Whoever told you that is wrong, its the other way round.
WEP is an older technology of encryption. Some older wireless devices won't work with WPA, but will with WEP. If all you devices can use WPA - then stick with that.
Nov 27, 2008 | NetGear WGR614 Router
Security Keys or Passphrase
  1. Now we will secure you wireless connection to prevent others from connecting. Under the Home tab, click the Wireless option from the left.
  2. Beside the SSID option, enter the name for your wireless network connection.
  3. Beside Security, select WPA. If you can’t connect using WPA, then select WEP. Using WPA will provide a much more secure connection that using WEP. For more information about WEP and WPA please read Wireless Security: WEP and WPA.
  4. Click AES beside the Cypher Type.
  5. Make sure PSK is selected beside PSK/EAP.
  6. Now you must get very creative. Specify a long Passphrase with a mix of upper and lower case letters, numbers and punctuation. Once again, please read Creating Secure Passwords for tips on how to do this. In this case the longer the better. Make sure you write down this key somewhere, either on a piece of paper or in a text document on your computer. You will need this information when you connect to your wireless network.
  7. Enter your passphrase next to Passphrase and again beside Confirmed Passphrase.
  8. Click Apply to save your security settings.
  9. Now you are all done securing your wireless router and network. All you need to do is connect to your network, and enter your Passphrase exactly as you specified it. I won’t go into detail on how to connect to your wireless network, as I will save that for another post.
May 10, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Gateway 4026GZ Notebook Logo
888 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
