Question about Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive
I plug my Dane-Elec USB portable memory into my laptops USB port, I get a check list like thing, the bottom two things are red. Someone about my key not being valid?
  • Dane-Elec Master
  • 27,725 Answers
Control panel,adminastrator,tools computer management,device manager should be a yellow?reinstall the USB drivers for this device
Posted on Jul 26, 2010
DANE-ELEC So Ready 500GB USB 2.0 Portable SO-MUJ1KP853371 Harddisk troubleshooting (Code 43)
This is a Driver issue. Search for updated drives.
If that doesn't work you probably need to contact a disk recovery specialist such as DATA365. http://www.datastor.net.au
Dec 06, 2013 | Dane Elec DANE-ELEC SoMobile 500GB USB 2.0...
My laptop has ceased to recognize my dane elec so speaky but wil still play on tv,whats the solution.
Have your tried calling the company??and having there talented crew do the hook up ??
http://www.youtube.com/watch?v=6dObVfXZpzs
http://www.youtube.com/watch?v=ZAPT4OWPihA
Hope all is up and running soon
Apr 07, 2013 | Dane Elec Dane-Elec Memory 2-Port Usb 3.0...
Dane-elec usb portable memory does not appear when plugged into my usb port
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Apr 10, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Is Zane-Elec 4GB USB portable memory (memory stick)compatible with Windows 98/98SE? Is a special Driver required? If so, where can I get it? Thank you, Bob
If it was engineered specifically for USB 2.0, it may not work at all, then again, it may work, just more slowly. Plug 'er in and see, shouldn't be able to hurt anything.
Sep 01, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane-elec usb portable memory stick - right protect error
pu *** into you rown pc again and format it. when it is done formatting reboot your pc and let usb in while rebooting. when its done you can use it again but when used take it out with "safely remove hardware" option.
hope this helps otherwise they have a return and guaranty service at least
sorry for grammar but im not english
Jan 02, 2009 | Dane Elec DANE-ELEC DA-M4-04-ML2 Meizu 4G...
I have no idea how to plug in my dane-elec 2 gb usb portable memory device
Sure can, On the side without a lanyard hole, Pull the "Cap" from the rest of the drive, This exposes the USB end, to be inserted into the computer usb..
Aug 10, 2008 | Dane-Elec DaneElec 1GB Dog Tag External...
My computer dosen't recognise that I have already inserted my portable imemory into g drive
hi there what type of computer are you using and what operating system windows xp or windows vista ? and did you go to the windows update website to get all of the current drivers and patches to recognize all new items being sold these days eg cameras usb drives and such did you try plugging into a different highspeed usb port ? are you using a usb expansion hub this gives you more usb ports for many things like printers and scanners and such . go to www.windowsupdate.com and get all avail updates for software and hardware ok good luck waiting on a fixya rating to see how this project went
Jul 20, 2008 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane-Elec USB not working!
How I got it to work in XP Pro:
1) Plugged USB Drive in and saw it saw hardware manager install it but didn't see new Drive Volume in My Computer
2) Opened Control Panel
3) Open System
4) Clicked Device Manager from Hardware Tab
5) Expanded Disk Drives
6) Right clicked USB Flash Memory USB Device and hit Properties
7) Clicked Volume Tab and hit the Populate Button. Voila!
HTH
May 12, 2008 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive Logo
206 people viewed this question
Top Dane-Elec Computers & Internet Experts
Steve
Piyal Perera
Piyal Perera
woodzowl307
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
