FixYa.com
Tags:
BenQ FP72G+  17
BenQ FP72G+ 17" LCD Monitor NO DISPLAY
posted by rickyykk on Apr 22, 2008
Thanks so much for your help ! =)
I've found 1 X 2SC5707 ( short circuit )
I've also found 1 X FU9024N (HexFET Power MOSFET) ( short circuit )
are there any other components that needs to be replaced associated with these 2 parts ?
please reply Thanks !
Comment by rickyykk, posted on Apr 22, 2008
I've replaced 1 X 2SC5707 (Q808)
I've also replaced 1 X FU9024N (HexFET Power MOSFET)(Q805)
re-soldered all the legs of the 4 transformers
but still not working, NO DISPLAY,
it's even worst this time, when i shine a torch on the screen, no dim display at all ???
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
Mark_Webber
Rank:Guru Guru
Rating: 88%, 264 votes
The way the circuit works is in a mirror format. There are 2 identical circuits that go to each end of the board.
Be sure to check that fuse for continuity, not just for a second like you normally would, but hold it for a good 10 seconds.
Also don't forget while you are in there it's best to repolace it anyway with an actual fuse. A 3A slow blow ceramic is good for this.
Check the 4 transformers as well, if you notice the top circuit is the faulty one, then check the transformers at the top. The transistors are quite powerful, and normally need something to trigger them into failing. Do the same for the bottom circuit.
This monitor came in 2 formats. One with 4 transformers and 4 CCFL tubes, one with 2 transformers that lead to 2 CCFL connectors powering 2 tubes each (3 wires per CCFL)
When you order the 2SC5707's get extras just to be on the safe side. If it goes again, then turn the monitor off immediatly and check them. It should only be 1 failed again, so just see which of the 2 transformers it was primarily attached to and replace it, or both.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Monitors problems?
Monitors
power saver mode
have a LG L226W (digital)... Answer This...
Monitors
Dead Monitor
Hi, I bought my parents an HP... Answer This...
Monitors
monitor isn't working!
At first, there was a hazy... Answer This...
Monitors
SERVICES MOOD OF CRT MONITOR
how to get services mood of... Answer This...
BenQ FP72G+ (Silver, Black) 17" LCD Monitor
LCD monitor
The backlight never lights and... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
