Question about Scitec TX-SP750-AS TELEMATRIX SPECTRUM PLUS 2-LINE ANALOG DISPLAY SPEAKER TELEPHONE (ASH)
Flashing phone button!!
I have a Telematrix Spectrum plus speaker 40-button telephone. The problem I keep having is that the line that says 'pickup' continues flashing when nothing connected with that button is being used. It won't stop until it wants to. I have tried pressing it while on the line and while not on the line. It just continues to flash until it decides to turn off. What can I do?
Will a Gigaset A220 A cordless phone work on a government spectrum phone line
If a telephone line is presented as POTS (Plain Old Telephone System) or a standard telephone will plug into the line, then the Gigaset A220 will work on it.
Feb 09, 2015 | Lands Phones
- blue message light on top of handset keeps flashing even though all messages have been read - have turned the power off taken batteries out but it still keeps flashing
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Aug 30, 2014 | Lands Phones
How i can activate 40 for my telephon?
40? It's the pickup code for a Panasonic system and it's the universal pickup code for phones in your ring group. Make sure that you and all the other people are in the same group and 40 will work. As an alternative, you can use the directed call pickup code. (41+extension) or program the phones to ring differently. This assumes a TA series system.
Dec 20, 2011 | Panasonic KX-T7730 Corded Phone
Will a panasonic KX-TG2257 cordless phone work with a KX-T6160 system?
I'm not familiar with a KX-T6160 system, so do you mean SIX-SIXTEEN-DEE(616d) or SIX-SIXTEEN-TEN (61610)? Either way, the cordless phone works. You need access codes, like 9 for an outside line, FLASH and dial an extension for transfer, 40 for ringing call pickup (on the 61610), and 58x (61610) to pick a line from hold. Your phone system manual has a single line telephone user guide in it.
Carl
Apr 30, 2011 | Panasonic KX-TG2257 Cordless Phone
KX-T3250B; the 5 red indicators on the upper right corner are flashing...
these 5 leds lights when phone is out of program. every phone should have his own indicator showing (when handset is off) his position in chain of phones. to make them stop flashing do following:
1. push and hold "PROGRAME" button until "MUTE" indicator lights (you'll hear beep sound).
2. push one "1" to "5" button on numeric keyboard depending on telephone's position in chain (must be unique).
3. push "MEMORY" button.
Now when you pickup handset only one indicator should light.
sorry, my English is not perfect :-(
Feb 04, 2011 | Panasonic Lands Phones
I am considering buying a Nortel T7208 2 Line phone for my home office. I have two separate lines, with two separate numbers. I need a phone that will allow me to plug both lines into the desk top unit. I...
Hi there...
OK, the Nortel T7208 set works only on a Nortel system.
It has only one line cord plugged into it, cause the telephone system can be programmed for more telephone lines and features from the system.
If you want just a home (analog) telephone service; look at Aastra/ Telematrix/ there are others - 2 line sets.
ONLY buy this Nortel set is you have a Norstar system. Otherwise the set will not work for you. It needs a system to run off.
Good luck in your search!
Aug 29, 2009 | Nortel Business Series Terminal T7208 -...
How do I get "call pickup" to work on a KXTES-824?
Two of the above codes work for me, so let's figure out what you're doing. First of all, did you convert the intercom calls to ringing on all calls? If I have auto answer turned on, I can't pick up anything.
If the phone is ringing, I can use 40 and 41xx to pick it up. I can retrieve a call from hold by dialing 53x where x is the line number on hold (just in case you're trying this with a cordless or single line set).
By default, all extensions are in pickup group 1, but 41xx directed call pickup will always work if the Call pickup deny is properly set as you indicated
Carl
Feb 16, 2009 | Panasonic Lands Phones
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
NEC DTU-8-1 telephone system
Press Feature, 69, then feature again. The light will go off.
Aug 10, 2007 | NEC DTU 8-1 Corded Phone
Scitec TX-SP750-AS TELEMATRIX SPECTRUM PLUS 2-LINE ANALOG DISPLAY SPEAKER TELEPHONE (ASH) Logo
Top Scitec Lands Phones Experts
Are you a Scitec Lands Phone Expert? Answer questions, earn points and help others
