Question about Roper REX4634KQ Electric Dryer
The dryer throws hot air, but the barrel inside will not go around
    President:
  • 3,074 Answers
It is either your belt broke, the rollers or your motor burnt out. you will have to take a screw driver and remove the front panel. Make sure it is unplugged. one the screws are removed you will have to pry the top up, it should pop off easy if not then you missed a screw. Lean the lid all the way up an look to see if the belt is around the drum, shold be in the middle and tight.
Posted on Jul 20, 2010
2004 camry ac light blinking and throws hot air. Suggestions?
My 2003 Toyota Camry AC often starts blowing hot air and the AC light starts blinking. I don't know why the following process works, but it does. Using the temp selector (left) reduce the temperature all the way down to Max Cold and then push the Auto button. It will start blowing out very cold air. After a little while push the temp selector to the desired temperature.
Apr 03, 2012 | Cars & Trucks
Dryer runs for a short period of time and then shuts down without any error code but with a "clean filter" indication. This happens when running any automatic cycle except "air dry". ...
it is proberly lint stuck around the motor and fan resticting air flow to the motor and the motor is shutting down because it is to hot vac out around the motor and inside the cabinet
Jul 04, 2011 | GE Profile DPSB620ECWW Electric Dryer
Ge DRYER dpgt750EC2PL back wall of drum gets very hot. Occassional smell as if something starting to burn. How do I open the top lid to get inside to find out problem
This may sound a bit over simplified but when a dryer starts to get hot inside it is a sign of an airflow problem.
Start with the outside vent flapper. Check to see if there is lint build up on the flapper / louvers.
Pull off the vent hose and check for lint build up. If the vent hose is a flexible plastic hose they have a tendancy to clog with lint in the sprials and then the lint contines to build up until airflow is restricted.
After checking external vents and ducts next remove the lint filter. If you use dryer sheets wash the filter with white vinegar to remove the build up. It may appear clean but the material from the dryer sheets clogs the filters.
In the area around the lint filter check the ducting / air passages for lint build up and clean it.
In the process of all the cleaning do NOT use anything sharp. A vacuum crevice tool and a Looped metal coat hanger do wonders for cleaning assistance.
Before you reconnect the dryer vent try running the dryer with a light load of anything wet to see if it drys properly with the vent disconnected. After that reconnect the vent and repeat the same drying test to see if the drying times are close to the same.
This should solve your hot dryer problem.. If it does not then respond here and we can talk about taking your dryer apart.
Thanks for using FixYa.
Kelly
the air flow out of the dryer it should be a very high volume.
Mar 15, 2010 | GE Profile Harmony DPGT750EC Electric...
Fisher and paykel clothes dryer wont turn with clothes in it.
Hi
Most dryers work with a belt around the drum. Either the belt is stretched and needs replacement or there may be a belt tensioner which needs adjustment to tighten the belt.
What is happening in your case is that the belt is slipping on the drum as it is too loose.
Best wishes,
Graemevm
Jun 18, 2009 | Maytag PYE2300AY Electric Dryer
My dryer does not get hot .
first i would check that the vent is clear. then go to the heating element.
May 23, 2009 | Whirlpool GEW9878LW Electric Dryer
Not drying
I know you cleaned the lint vent but your vent hose is clogged or damaged and there is no air exchange thru the dryer Air can only hold 100% humidity. You could dry your clothes for 10 hours but the air in the dryer is saturated with water and can not hold anymore so your clothes wont dry. Check behind your dryer and Ill bet the vent line is damaged. The problem is the air is not getting out of the dryer. Check the flapper at the end of the vent line. With the dryer running go to the end of the vent hose and there will be no air coming thru.
Oct 15, 2008 | Roper REX4634KQ Electric Dryer
Not dring
The air is not getting out of the dryer. Your vent hose is crimped or cloged or the flapper outside the house is stuck.. Air is not getting out of the dryer thru the vent for what ever reason.
Drying time is longer than usual.
Check if you have a reasonable amount of airflow when it is operating. You may have a broken connection in the joint or a problem with the dryer fan,
May 17, 2017 | GE Dryers
Won't dry
Sana, this will sound trite, but did you check your breakers? The breakers for your dryer will be in the main panel, outside the house. There will be two breakers dedicated to this circuit, probably 40 amp. If one of these is tripped, the unit will tumble but not heat. If the breakers are OK, I'm sorry to say that this problem will require the services of a professional to diagnose. There are a series of safety thermostats and a thermister that electricity must flow through before reaching the element. If any ONE of these fails, the unit will not heat but will still tumble. Sorry I couldn't be of more help.
Jul 31, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Roper REX4634KQ Electric Dryer Logo
63 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
