Question about Car Audio & Video
I have just purchased a meos mc701b in car player with gps module.followed the wireing instructions but the power light on the gps box keeps flashing on and off.does the pink wire need to be wired up to the handbrake because everything else seems to be working fine
The pink cable needs to connected to the either the handbrake or the ground (black) cable
Posted on Jan 15, 2011
NO THIS IS OK THE PINK WIRE IS FOR DVD VIEWING
Posted on Aug 14, 2010
I have a 2 year old Meos 192B TV. It works perfectly on 220V but not on 12V. What could the problem be?
I suspect there is not enough power to run the TV. Does it work in your vehicle with the supplied power lead.
Jan 31, 2017 | Televison & Video
I have bought a BMW with Meos MC701B installed without a manual. How do I reset the whole thing as does not play any sound when iPhone is connected.
Turn on the head unit. Connect the iPod, then turn on the iPod. The device should then automatically play in IPOD mode.
If you could use the German translation of the manual, then here: http://www.gsl-servicenet.de/jetweb/media/PDF/Bedienungsanleitungen%20AGIS/InDash_German/QSG/MC701B%20german%20qsg.pdf
Nov 29, 2014 | Cell Phones
Can not start run?
follow this steps and fix it. Merry Christmas
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
Main Control Module / Timer
The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace main control module. this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
Dec 19, 2013 | Meiko DV80.2 High Temp Door Type...
Does anyone know where i can buy the meos naveme 120 gps navigation module for my meos mc702b?
I am looking for one of these as well. Maybe, if they're discontinued we could buy a couple cheap!
Jul 24, 2012 | GPS
Multiple lights flashing on control panel
see this causes and fix it: God bless you
1) try to tight the wires connector well to the control board, clean it , but unppluged the power
2) dry solder, try to resolder+control board faulty
3 see the following steps:
Power Supply
The main power supply is the first thing to check. Also remove the toe kick and the cover on the power box and check the connections. Also check for 120 volt at the power box.
Hi - Limit Fuse
This will fail if your dishwasher overheats and occassionally with power surges. This is easy to check, inexpensive and a quick fix. Just check the terminals for continuity ( remember always remove one wire) if you have none replace the hi limit fuse.
Door Switch
This is the second place to look. Again an inexpensive easy fix. The following video will walk you thru checking the door switch. The power comes into the main power box and usually runs to the door switch next before entering the main control module.
The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace the control module, this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
Motor
The motor may have failed. If the control illuminates on electronic versions the problem may be the motor. To check the motor refer to the tech sheet located behind the console cover on most models, this will sometimes have the ohm reading of the motor. Also check each lead to the metal housing of the motor to check for shorts in the motor. If you do not have the ohm reading specicifications, check for continuity if none replace the motor. Make sure the motor is recieving power.
Float Switch
If the float switch has failed or is stuck the dishwasher control may not respond. The float switch is easy to check and replace. We have video and tutorials that cover several styles.
Jul 21, 2012 | Whirlpool GU2400XTPS Built-in Dishwasher
Installed Meos mc701b with navme 120gps nav system. All fine except that the sound on nav instructions is very low and see no means of resetting it. Any solutions? Seems a common problem
This is simple - go to the NAVI screen itself via the menu - turn the volume up using the volume up key.
Return to the radio and now hold down the menu key - you will go back to the sat nav screen with the radio playing in the background - when you now get voice prompts they will be louder than before!
Nov 10, 2010 | Car Audio & Video
I have a meos mc701b coupled to a meos navme120 and i cant get the satnav to work it just keeps flashing up the same message "no signal" any ideas
Go to GPS hardware and select "locate" then try the different port options - it will be on one of them - problem solved.
Jun 27, 2010 | Car Audio & Video
How to connect hand brake cable on meos MC701B
if you can get to the hand brake, there is usually 1 wire coming off of it at the base, you will want to test it to make sure it is sending the ground pulse, just splice it into that wire. If you want to save yourself the headache, just put a switch to a ground (-) and hook that up to the handbrake wire (coming from the unit). It will do the exact same thing, but with a lot less work.
Apr 29, 2010 | Car Audio & Video
Meos GPS Navigation Module with UK+EURO Maps haw
iF U CANT GET TIME TO CHANGE TO SAME TIME AS THE HEAD UNIT. IN THE SATNAVE SOFTWARE U NEED TO GO TO MENU / GPS HARDWARE/ SYNC TIME. THIS WILL SET THE SATNAV TIME TO SAME AS HEAD UNIT SO SET IT FIRST
Dec 14, 2009 | GPS
Car Audio & Video Logo
729 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
