Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Freezer defrosting Our Whirlpool Gold Model# GD5SHGXKQ01 must have started defrosting today. We have turned off the freezer part for a while to see if that helps. It also no longer makes ice. The refrigerator side seems to not be as cold either.
  • karen23847 Apr 23, 2008
    Thanks. We ended up calling a repair man and it was some kind of relay switch. It was close to burning up. So I am glad we just lost some food.
    Genius:
  • 1,073 Answers
You have a defrosting issue for sure, you neeed to unthaw the freezer coil first and then find out if the defrost heater the defrost timer or the defrost bimetal is the issue one of these three parts is bad
Posted on Apr 22, 2008
Bottom freezer door stuck closed due to food blocking. How can I get door open? Whirlpool Gold Model GX5FHDXVQ01
Hi Pat, that's a tough situation. Are you able to get the door open at all to slip something long through like a piece of wood to maneuver stuff around in the freezer?
If you can't, maybe turn down your freezer to start a defrost, or do a complete defrost.
Sep 04, 2016 | Whirlpool Refrigerators
My Whirlpool Gold Series Fridge is not cold in Fridge part, but is still working in freezer part. What might the remedy be?
Could be a few things. One could be a bad evaporator fan motor in the freezer section. The fan motor will only come on when the light switch is closed so make sure you hold down the light switch when you check it. Could be a defrost timer or defrost bimetal. You will know because you will have ice buildup on the back wall inside the freezer. Also could be icebuildup in the return air duct. They are located under the drawers in the refrigerator.
Oct 19, 2014 | Whirlpool Refrigerators
I have a whirlpool gold model# GX2FHDXVQ02 S/N# K02263328 and the freezer section needs to be defrosted. How do i defrost it?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 27, 2011 | Whirlpool Refrigerators
The Whirlpool Gold refrigerator is not cooling and the bottom freezer has ice formed on the back of the freezer. I purchased the refrigerator in February 2009.
If you can hear the fan running in the freezer you have a defrost issue. Depending on the Model number it can be a timer, adaptive defrost board, a bi-metal themostat, or heater.
May 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Whirlpool Gold Model GS5SHA Side by side. Freezer working, refrigerator side not getting cold.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 06, 2010 | Whirlpool Refrigerators
Freezer issues with Conquest
freezer is supposed to defrost? need more info..
if you need a part try www.appliancepartssolutions.com
Jan 16, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool Gold freezes up to frige side
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water buildup in the fridge, dripping in from the freezer
This could be a bad thermostat. If your thermostat never closes it's swith then the defrost element never comes on and you get the problem you are having. Easy fix. Do you know where your timer is and can you retate it?
Jul 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
237 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
