Question about InFocus ScreenPlay 4805 Multimedia Projector
The picture suffers from colour fringing
I have a homr projector set-up in my back room. However, lately the picture suffers from colour fringing (especially dark images) and after a set time the colour goes very wrong with the picture looking something like an Andy Warhol painting- as though there is no red part of the image. I replaced the lamp but the problem has persisted.
The projector is an Infocus IN80EU.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
Either the color wheel has lost a segment or the colorwheel index needs to be adjusted in the hidden menu using the color ramps test screen.
Posted on Jul 20, 2010
Haze
Rather hard to properly diagnose this one off such a short description, but...
1/ Bulb OK, not over hours or otherwise damaged?
2/ Is it constant for all images, just a general coloured haze, not a strange "shadow", "ghost" or "fringe" that alters depending on what you display?
3/ Lens nice and clean?
4/ Surface you're projecting it onto also clean and at least nominally white?
5/ Input cables all fine at both ends and work correctly with other output devices (TV and/or computer monitor)?
6/ Haze still in place with different cables and input devices?
7/ Does the projector regularly show the same static image for extended periods?
The VT460s were buggers for suffering from internal LCD and filter glass issues if allowed to overheat, and with image burn-in, especially if fitted with unusual lenses (e.g. extreme short-throw); I've had to do internal cut-and-swap surgery on a few of them before, with donor image elements from projectors that died due to other problems. I can't say the one VT470 has shown any sign of similar, but the two VT480s are worse if anything. So it's entirely possible that we just got the one good VT470 out of the whole production run. As intimated by the above, it could be anything out of a failing bulb, dirty lens (or internal image element) glass, image burn-in, LCD/filter damage from overheating (and mind that being turned on showing a "blank" screen for ages can cause a similar effect, as all of the bulb's 200 watts of light energy is then being completely absorbed by three thumbnail-sized pieces of liquid crystal... the bulb doesn't turn off unless the projector is shut down completely!), problems with internal circuitry, dodgy cables, unsuitable projection surfaces, or problems with the devices feeding images to it. It really is a minefield until it can be narrowed down.
May 11, 2012 | NEC VT470 Multimedia Projector
Picture way too dark to watch comfortably. Have already adjust all settings to maximize brightness. Bulb was replaced late last year and says 1,000 hours have been used but projector has not prompted me...
Unfortunately dim image is normally due to a defective lamp assembly. I'd recommend removing the lamp and inspecting its condition. You'll notice black corrosion build up or a bubble is starting to form around the filament of the bulb if it is what's causing the dim image.
Aug 06, 2011 | Mitsubishi HC1600 Projector
We have a Mitsubishi sd200u projector.The right side of the screen is dark,there is still picture but very dark.We thought it was the bulb,ordered and replaced that,and we are still having the same...
Does the dark side have a well defined straight vertical edge or is it ragged and blurry.
Is the picture still visible in the dark area, or has the picture disppeared and there's this darkness that has taken over.
I'm thinking that the optics may have been jolted. Has the unit suffered any impact or the like.
Mar 19, 2011 | Mitsubishi SD200U Multimedia Projector
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
Dark horizontal bands appear on projection
Your matrix is failing. If the unit is under warranty, send it back.
The matrix is the bit that allows light to come through of each colour. If its failing one colour won't get through. If the circuitry is failing, more than one colour wont get through.
Jul 12, 2009 | LG LP XG2 Multimedia Projector
When trying to watch a film off the computer through the projector the colour red comes out green on the projector.
check your cable and use a different laptop or desktop to eliminate the projector. always do a factory reset.
Sep 08, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Sharp TV model 27H-S60 convergence
HI ,USE A PATTERN GENERATAR DOT OR LINES TYPE AND USE THE CONVERGANCE RINGS BEHIND THE YOKE OF THE SET ,THERE ARE THERE RINGS FOR EACH COLOUR RED GREEN AND RED .SLIGHTLY MOVE THE RINGS AND U CAN SE EIN THE PATTREN THE COCLOUS WHICH IS FRINGES EACH BY EACH U ADJUST ALL THERE RINGS FOR PERFECTION , FIRST LET THE SET BE SWITCHED ON FOR 1 HOUR AND THEN DO THE ADJUSTMENT. THANSKS
May 22, 2008 | Sharp 27H-S60 TV
Dark Colours pixelate on screen
hey i have the same prob with mine (same model) but it only happens when i send the picture through the rca video in. if i use my pc and use the 15 pin plug, it works fine. i cant explain why it happens, but i jus know it happens.
Aug 11, 2006 | Acer PH110 Multimedia Projector
Pink Edges in Photos
It is called 'purple fringing' or chromatic aberration. It is quite common with digital cameras, especially those with small sensors. Sending the camera in for repair would not help at all. It can be removed, quite labouriously, in photoshop. Usually it is very seldom so obvious that it would require corrective work. When it is, it is often only in a small part of the image making it not that time consuming to fix in photoshop.
Sep 14, 2005 | Canon PowerShot A70 Digital Camera
InFocus ScreenPlay 4805 Multimedia Projector Logo
222 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
