Question about Typhoon Bass Vibration Headset
Hi i have a pair of typhoon headphones and the sound is only coming out of the left headphoneany ideas on how to fix this?
Sound coming through right headphone, but not through left. Sound also not coming through left speaker. Help?
are you adjusting sound through the windows controller or the application you're playing music through? there are a few things that could affect that, there's also the actual sound setup where you can change your setup i.e. surround sound, single speaker, headphones etc
Oct 02, 2013 | Toshiba Satellite Computers & Internet
Sound comes through only one speaker at a time.
Is the sound on both channels on a pair of headphones? If it is suspect a faulty headphone socket, especially if the speakers are cut out when the headphone jack is inserted - normally.
Jun 15, 2013 | Technics Audio Players & Recorders
I just installed my vestax typhoon and the drivers. everything seems to be running fine but i can only listen through the headphones plugged into the controller. no sound comes through my laptop speakers....
Make sure the Windows computer has the audio output selected to use the computers output hardware.
In the control panel, under "sounds and devices" pane, VOICE tab, that the Voice playback window shows your COMPUTER's audio system AND then check the volume is turned up by clicking the Volume button right under that same window. Now do the same under the AUDIO tab at the sounds and devices pane.
Feb 11, 2011 | Vestax Typhoon USB DJ MIDI Controller with...
I m using hytech sound card but in sound headphone is not working
sir if you are using sound card then your front jacks gets disabled
thanx
Jul 25, 2010 | Typhoon Anubis Typhoon Silver Crest 3D...
Sennheiser RS126 headphones/base stopped working
Broken audio cable entering the transmitter or audio jack plug.
Power supply plug loose / faulty power supply.
Nov 10, 2017 | Sennheiser RS 120 Consumer Headphones
Sony MDR-NC11 Left Earbud has no sound
They should come apart right where the metal meets the plastic, just below the buds themselves - be careful, one set like that I took apart were actually surface-mounted to the housing, there weren't any leads to repair...
May 27, 2009 | Sony MDR-NC11 Consumer Headphones
Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Nov 25, 2008 | Denon AVR588 Receiver
Bose in-ear headphones sounds cuts in and out
Well, here's a temporary fix until you guys can get new ones. Pull the plastic stopper about halfway up the phones. Then loop the bottom of the entire headphones through the circle that the plastic stoppers create. When you have a tiny loop, pull the upper stopper down and tighten it. People said that they needed to angle the cable in a certain way, right? Well, this fixed mine for now. Just keep it in that position until you can get a replacement or they come up with a permanent fix.
Feb 20, 2008 | Bose in-ear headphones - Black with...
Sound problems on my D-NE720
!st, try a different pair of headphones. If the problem persists, the jack is breaking from the PCB and will need to be resoldered.
Sep 17, 2007 | Sony D-NE720 Personal CD Player
Typhoon Bass Vibration Headset Logo
62 people viewed this question
Top Typhoon Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Typhoon Radio Communication Expert? Answer questions, earn points and help others
