Question about Zebra Eltron TLP 2844 Thermal Label Printer
How do i resolve err01 on my zebra LP2844 printer?
itdude4321
  • 13 Answers
SOURCE: NEED THE DRIVERS FOR MODEL NO LP2844 ZEBRA
I have found that some times the zebra driver don't work well with Xp or Vista. Try these drivers :
http://www.seagullscientific.com/aspx/thermal_95.aspx
They have never let me down.
Posted on Feb 03, 2008
SOURCE: problems with Zebra Lp2844
I have a HP All-in-one F380 that will not print.At the bottom of the screen it says '1 item in queue. How do I get this item out of queue? Please
Posted on May 11, 2008
PABLOCSA
  • 1124 Answers
SOURCE: LP2844 printer only prints after reboot
Probably you have some conflict on your printer ports. Go to your installed printer (Printer folder) and select one of them, >> righ click >> go to properties >> Ports
and see which port is taking the first printer, which is taking the second one and which the third one. It is problably than 2 of them are using the same port. (Virtual USB)
Posted on Oct 03, 2008
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Posted on Mar 11, 2009
  • 32 Answers
SOURCE: LP2844 Printing light
You should first make sure the printhead is clean. If the printhead is dirty and you crank up the darkness, you will blow the printhead elements. Open the printer and from the bottom, you will see the printhead, which has a glass like appearance. There is a green strip from one side of the printhead to the other. Take a que tip with some rubbing alcohol and wipe it clean. I would make sure the printer is turned off before doing so. Just to be safe.
Posted on Oct 27, 2009
How do you load the ink spool on a new Zebra LP2844? we cannot find where it goes? Elaine
Hello Elaine,
The LP2844 does not use any Ink or Toner. The labels are heat sensitive thermal paper and when the print heat gets hot they show an image.
Aug 31, 2011 | Zebra LP 2844 Thermal Printer
What is the difference between the Zebra LP 2844 Thermal Printer and the Zebra LP2844Z?
lp2844 use programming languages EPL2, Line Mode, lp2844 use ZPL II, ZPL (Zebra languages), both are Direct Thermal (don't use ribbon), not Thermal-Tranfer (use ribbon).
Nov 17, 2010 | Zebra LP 2844 Thermal Label Printer
I have a Zebra LP2844 Thermal Printer from UPS. I
Welcome to the club. Been fighting this for almost a year. There is now a driver for vista available from Zebra to fix. I can now print 1 label from quick books. to print a second i have to restart computer and quick books. still searching for the answer.
Dec 08, 2009 | Zebra LP 2844 Thermal Printer
Zebra lp2844 printing incorrectly with paypal multi order
Same here... Can't be the printer - has to be something with either the paypal software or the driver since my 'SAMPLE' prints solid as well. Did you ever find a solution?
Oct 15, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 print is wrapping horizontally
Update the printer firmware, download latest printer driver from zebra website.
Oct 01, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 cannot print LABEL
Please be aware that zebra Lp2844Z is different with LP2844.
LP2844 - Eltron
LP2844Z - zebra
please make sure the programming language is correct
Aug 23, 2009 | Office Equipment & Supplies
I need the driver for Zebra LP 2844 for MAC OS X.
OS X 10.5.2 and above have built-in ZPL and EPL drivers. Plug the printer in to USB, go to System Preferences > Print & Fax, click + , and choose the Zebra driver. For the LP2844 you choose the EPL2 driver.
Apr 09, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Mar 24, 2009 | Zebra LP 2844 Thermal Printer
Dec 22, 2007 | Zebra LP 2844 Thermal Printer
Zebra Eltron TLP 2844 Thermal Label Printer Logo
1,228 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
