Question about Kenmore Refrigerators
Refrigerator leaking water
Water collecting and overflowing under the vegetable drawers at the bottom of fridge. Non ice model Kenmore 106.69172990
  • paulekas Jul 21, 2010
    I ended up calling a repair man who fixed it.
  • 532 Answers
Usually this is a common problem most often caused by a blocked drain hole or a crimped/blocked drain tube. The water comes from melting of frost from your refrigerator’s freezer, which is melted during defrost cycles.
The water then flows down a drain system, usually from a hose that takes it outside of the refrigerator, and into a drain/overflow pan. This pan has many names: drain pan, condensing tray, overflow tray, evaporator pan, but they all serve the same function, as place holding place where water from the freezer is caught and held until it evaporates naturally.
Blocked drain line when the freezer goes into defrost.
Thanks for contacting Fixya.
Posted on Jul 20, 2010
  • 2 more comments
  • paulekas Jul 20, 2010
    How do I unplug the hose?
    How do I fix it?
  • Rahman Rufai Jul 21, 2010
    Unplug the refrigerator and then locate the drain hole which is usually
    found at the back of the unit
    Pull out the basket and look for the drain hole. Some refrigerators like
    Magic Chef have drains located behind the bottom basket in of freezer.
    Remove any ice that is blocking the hole with
    a hair dryer.
  • Step 4
    Snap off the panel covering the plastic funnel tray used on
    some refrigerator models. This panel snaps off to reveal the drain tube.
    If the drain tube is covered with ice, thaw it out using your hair
    dryer.
  • Step 5
    Inspect the top of the drain tube for any debris that may be
    blocking it. Remove debris if there is any present.
  • Step 6
    Fill a regular turkey baster with hot water and squirt it
    down the drain tube. The heat and force of the water should unblock the
    tube and drain out into the pan. If that occurs, replace the snap on
    cover, put back in the freezer basket, and then plug in the
    refrigerator. If none or very little water has drained into the pan,
    there is still blockage. Go to the next section
  • Read more: How
    to Unclog a Refrigerator Drain in a Magic Chef Refrigerator |
    eHow.co.uk
    http://www.ehow.co.uk/how_5671723_unclog...
    funnel tray used on some refrigerator models. This panel snaps off to
    reveal the drain tube. If the drain tube is covered with ice, thaw it
    out using your hair dryer.
  • Step 5
  • Step 6
    there is still blockage. Go to the next section.
  • Read more: How
    eHow.co.uk
    debris that may be blocking it. Remove debris if there is any present.
  • Step 6
  • Read more: How
    eHow.co.uk
    and squirt it down the drain tube. The heat and force of the water
    should unblock the tube and drain out into the pan. If that occurs,
    replace the snap on cover, put back in the freezer basket, and then plug
    in the refrigerator. If none or very little water has drained into the
    pan, there is still blockage. Go to the next section.
    Speaker Wire as a SnakeGrab a length of speaker wire that is as long
    as the refrigerator to unblock a drain hole that is still blocked.
  • Step 2
    Using this wire like a drain snake, carefully insert it down
    the drain tube using an up and down movement.
  • Read more: How
    eHow.co.uk
    insert it down the drain tube using an up and down movement.
  • Step 3
    Thread it in fully all the way down to the drain pan. This
    will positively remove any remaining blockage including food and stuck
    on paper. Once it reaches down to the pan, pull your snake out of the
    drain hole, fill your turkey baster with water, and squirt it down the
    tube. It should drain out quickly and easily.
  • Read more: How
    eHow.co.uk
    drain pan. This will positively remove any remaining blockage including
    food and stuck on paper. Once it reaches down to the pan, pull your
    snake out of the drain hole, fill your turkey baster with water, and
    squirt it down the tube. It should drain out quickly and easily.
    Replace the snap on cover, put back in the
    freezer basket, plug in the refrigerator, and you are all set.
    jQuery('.article ol .image').each(function(i,e){
    var $this = jQuery(this);
    $this.find('img').error(function(){
    jQuery(this).remove();
    $this.remove();
    Thanks.
  • Step 4
    Replace the snap on cover, put back in the freezer basket,
  • Read more: How
    eHow.co.uk
  • Step 1
    Grab a length of speaker wire that is as long as the
  • Step 2
  • Step 3
  • Step 4
  • Read more: How
    eHow.co.uk
    I have a bottom freezer model # RB215ABBP/XAA with ice behind and inside the right-side vegetable drawer; some vegetables froze. Why?
    Samsung has had this issue for a long time now. The problem is the drain in the refrigerator is clogged and leaking inside. If you remove the drawers and look back then you will probably see a rusty line where the water has been leaking and you will see water under the bottom long deli drawer.
    If it has been leaking for a long time then it is recommended to replace the evap cover in the fridge section as the foam gets waterlogged and will cause future issues. If it just started the you should be ok.
    There is a new drain kit part# DA82-01415A that will solve this issue.
    The fridge should be defrosted for 24 hours prior so you can get the evap cover off without damage from the ice (unplugged and doors open for a full 24 hours. Longer times may be needed if this has been happening for longer then 2 weeks.)
    Feb 11, 2018 | Refrigerators
    Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
    This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
    I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
    Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
    Water accumulating inside fridge bottom make GE Model #gta18pbnaww
    That's normal especially if you tend to leave the door open alot. Moisture from the outside air condenses and drips to the bottom. Also, if the refrigerator is automatic self-defrosting it will melt ice collecting around the refrigerator and the resulting water will collect at the bottom. Check under the food drawers for a drain hole. If it is clogged, clean it out. If it doesn't exist, periodically sponge out the bottom under the drawers.
    Jan 12, 2013 | Refrigerators
    Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
    Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
    Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
    Water under vegetable drawers
    Look on the top back of ur fridge. in the middle of it u should see a resetacaple. if it is full of water and over flowing there is ur problem. then u have to check about ur cooling unith if not change the setting of u fridge let the frizzer frezze and the fridge stay a bit warmer
    Nov 19, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
    Bottom of fridge under vegetable drawers lots of water collects. Every two days have to soak up.
    I assume it's a top freezer model. The drain is either blocked, or frozen up. You'll have to be able to remove the the rear panel in the FREEZER compartment and inspect.
    One other thing that can cause this, is if you have an Ice maker, and when filling, the fill hose to the ice maker hose has become dislodged.
    Oct 19, 2009 | Whirlpool Refrigerators
    Water/liquid collects at bottom of refrigerator under vegetable drawers
    For water collecting inside of a refrigerator, there is usually something leaking inside, or perhaps the door seal is letting moist air into it.
    Jul 08, 2009 | Kenmore Refrigerators
    Leak gathering under produce drawers inside kenmore fridge
    I can send you a video of that problem if you like. It's a Youtube video.
    seabreezehvac@yahoo.com
    Feb 28, 2009 | Kenmore Refrigerators
    GE Refrigerator, Model TBX22ZA
    the drain hole is blocked in the bottom of the fridge. if the water is not able to drain down the hole it will overflow into the fridge base. check any holes at the inside back of the fridge.
    Jun 11, 2007 | Kenmore 26.0 cu. ft. Side-By-Side...
    Fridge bottom has water under vegetable drawers
    Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
    May 16, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
    Refrigerators Logo
    106 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    oldblindman
    Level 1 Expert
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
