Question about Garmin StreetPilot c340 GPS Receiver
Garmin c340 will not turn off and I cannot see a reset hole.
  • 504 Answers
Your unit has a reset button under the faceplate. There is an indentation under the top of the faceplate. Insert your fingernail and gently pry it forward. Pull the whole faceplate off, and you will see the reset button on the bottom right of the unit. I hope this helps.
Posted on Jul 21, 2010
Garmin c340 frozen in on position does not turn off when power is pushed stuck on arrival time
Look on the back or on the side someplace, what you are looking for is a small hole, just a little bigger then a paperclip. This should be the reset button, hit that with said paperclip and then allow the system to reboot. This should clear up the problem.
Mar 12, 2010 | Garmin StreetPilot c340 GPS Receiver
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
The screen on my Garmin Street Pilot C340 is frozen
I read the manual. There is a reset button underneath the plastic cover surrounding the screen (pry off w/ your thumb) -- push the reset if the power can't be turned off otherwise.
Oct 01, 2009 | Garmin StreetPilot c340 GPS Receiver
My Garmin StreetPilot c340 is frozen.
No.......the C340 STREET PILOT has a hidden reset button. Put your fingernail in the slot just under the GARMIN name on the front face plate. Gently pull the face plate outward. Don't take it all the way off. The reset button is on the right side of the front screen just under this plate. Use a pointed object and hold the button IN for 3 seconds and unit will turn off. When you power it back up it will REBOOT.
Jun 03, 2009 | Garmin StreetPilot c340 GPS Receiver
H ow do i reset my garmin street pilot c340
To reset the Garmin C340 you will need to pull the Bezel off that goes around the screen. There is a reset button under there. Make sure that is what you really want to do before you do it.
Harleyknut
Mar 30, 2009 | Garmin StreetPilot c340 GPS Receiver
My garmin streetpilot c340's screen turns on and then goes black. I have it plugged into my car but it still won't stay on.
I found the solution on another blog. He said to try resetting the reset button . It worked. The button is located under the front screen. Remove screen frame by fingernail under the Garmin name. I'm thrilled. navinscs
Jan 25, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin nuvi 350-can not change the location it is stuck on
you may need to reset it, as in resetting the c340, turn off and then press back on again, if this does not work maybe the reset button is in the same place as it is on my c340, instructions for the c340 is as follows: place your thumb nail in the groove located under the Garmin logo on the face plate, gently pull off the face plat, press the reset button, turn the unit back on and hopefully it will operate normally
Dec 28, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin c340
First, be sure you are outside, in the open when making this diagnosis. Some cars have metallic defrosting layers, which blocks the GPS signal. If, when outside in clear view, you still have problems, try this...
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get the unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Jun 06, 2008 | Garmin StreetPilot c340 GPS Receiver
Screen frozen
Be aware - A Master Reset WILL ERASE ALL OF YOUR FAVORITES. To do this, turn the unit off. Press and hold the bottom right side of the screen and turn the unit on.Keep pressing the screen until the unit asks if you want to reset. Press yes. This will do the Master Reset.
Mar 30, 2008 | Garmin StreetPilot c340 GPS Receiver
My Garmin Streetpilot c340 is locked up.
There is usually a small hole somewhere on such units that lets you insert a paper clip or a pen to reset. It is often marked reset, but not always. Look for a round hole about 1mm diameter or less. On a Garmin such as yours it should be on the back. It might actualluy be to small for a paper clip, to you might try a safety pin or soething thinner. Make sure the hole isn't a speaker, as you might ruin it by putting a paperclip in. Also check your manual to see where the reset hole is located. It should state this in the trouble shooting section. My TomTom Go 700 has the reset hole on the mounting bracket on the underside.
Mar 09, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
508 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
