Question about Kodak EASYSHARE M340 Digital Camera
I've had my Kodak Easy Share M340 charging all day, and it still only displays a partial Kodak logo during the initial start up, and then turns itself off...
I have the same problem & the battery is the Li-ion. I just bought this camera this spring!!!
Posted on Aug 10, 2010
  • Kodak Master
  • 6,826 Answers
How old are the Kodak batteries and are they Li-ion?
Posted on Jul 20, 2010
  • Duane Wong
    Duane Wong Aug 10, 2010
    If the camera doesn't seem to work with charged up Li-ion batteries, then the camera should be sent in for service at kodak.com.
I have a kodak easy share camera M340 and I can't take any photos since it says Internal memory is full. Help
Buy yourself an SD memory card and transfer your pics to the card. That will clear your internal memory. You can save all your pics that you take from now on in the SD card.
Sep 10, 2011 | Kodak EasyShare Z612 Digital Camera
How i can remove the date stamp from my kodak photo?.I hav kodak easy share M340.
Press the MENU button. Use left/right to select Setup, then up/down to select "Date Stamp".
Nov 16, 2010 | Kodak EASYSHARE M340 Digital Camera
Need a manuel for Kodak Easy share M340
Both the user guide and the extended user guide are available for online viewing and/or downloading at
http://www.kodak.com/global/en/service/products/ekn036196.jhtml?pq-path=14648
Aug 31, 2010 | Cameras
Kodak EasyShare M340 Digital Camera
Maybe, the batteries need to be changed to new ones.
Try to use Li ion batteries as recommended by Kodak.
Jul 23, 2010 | Kodak EasyShare M853 Digital Camera
Camera battery shows that it is charged. Camera will not stay on
kodak easyshare m340 turns on for a second and then turns off
Jan 09, 2010 | Kodak EASYSHARE M340 Digital Camera
My Kodak Easy Share M340 won't turn on!
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean both ends of the batteries, place them back in the camera and give them a full charge. This cleaning clears the problem about 80% of the time. If it doesn't work for you, it may be time to replace the batteries, or the camera may have a problem that requires professional repair.
Jan 04, 2010 | Cameras
My Kodak Easy Share M340 is having a problem. When I turn in on the lens opens and hen closes right away.
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 16, 2009 | Kodak EASYSHARE M340 Digital Camera
Problem with M340 Kodak easy share digital camera..( automaticall
I had the same problem after a day at the beach. What I did was get a can of compressed air (from the computer section) and blow air around the lens as I repeatedly turned it on. It took about five cycles, but I eventually cleared whatever was preventing the lens from fully opening.
Good luck.
Aug 17, 2009 | Kodak EASYSHARE M1063 Digital Camera
I have lost the manual when moving house need
Kodak has at least two cameras with the 340 number. You can find the manuals for those two on the manufacturer's web site
C340: http://www.kodak.com/global/en/service/products/ekn030242.jhtml?pq-path=6840
M340: http://www.kodak.com/global/en/service/products/ekn036196.jhtml?pq-path=3905/11249/14648
Apr 26, 2009 | Olympus Camedia C-765 Digital Camera
Kodak EASYSHARE M340 Digital Camera Logo
311 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
