Question about Canon PowerShot SD600 Digital Camera
Installation CD My CD Drive won't read the Installation CD because it says that the CD is corrupted...
  • 975 Answers
SOUNDS LIKE THE CD Drive needs to be re install , go to MY COMPUTER , and right click where the CD drive is , opens a window , go to properties and go wheres a TROUBLESHOOT word is click and let the comp run a diagnostic , hopefully it will be re install.
Posted on Apr 22, 2008
Motherboard for hp pavilion xt963 is there away to tell if its bad
It's very possible that your hard drive is dead. If you get a prompt when booting it such as F1 then the motherboard is working (so far), therefore it means the BIOS is ok and also that your CPU is ok if not nothing will show on your screen. If pressing F1 gives you boot options then select CD. If it won't boot from your CD force it by actually going into BIOS setup and selecting CD as primary boot drive then press F10 to save. (if BIOS setup options don't show when booting try pressing F10 or F8 and any other function keys after F1.
Make sure you have the installation disk. If the PC still doesn't boot or detect it you should try another CD/DVD drive, yours might be bad or buy or borrow a DVD/USB external drive and select it as boot drive in BIOS. Often I've seen that when booting if either the hard drive is bad or your operating system is corrupted it will prompt F1 because it cannot detect either. If OS is corrupted you will be unable to get to safe mode especially if the hard drive is bad, the recovery partition is on that hard drive and safe mode is a Windows program not BIOS.
After you've tried connecting a different CD drive to install your OS you should be able to at least see the Windows installation or whatever operating system you use asking to begin installing. If the installation fails then we move on to the hard drive; take it out and put a new one then try again.
If none of these help then there might be a circuit shorted out on the motherboard which can cause some things to work but not others although this is rare. Lastly I don't know what you meant by USB in your question because unless you have a bootable USB drive the system isn't going to do anything with it anyway.
By the way someone here mentioned RAM memory. BIOS should still show even if your memory is gone but some systems are quirky so this needs to be tested as well. I could go further if you had posted your system's specifications such as how many sticks of RAM you're using. Try dusting off your the inside of your computer with compressed air. Dust acumulation tends to cause weird behavior on a computer.
May 14, 2012 | Intel Motherboard
My hp series HSTNN-105C WON'T BOOT INTO THE OS
This indicates a hard drive problem or windows files has been corrupted. If you have a cd installation disc load your operational system, if that fails have the hardware tested for possible replacement.
May 07, 2012 | HP HDX16-1370us (NV032UA) PC Notebook
Sir plz. help me, during installation of my winxp operating system, it stop copying of setup and it appears that driver.cab cannot copy,
Hi, "Cannot copy file" Error occurs when the setup fails to read the data/ file from the CD/DVD. This could be due a corrupt, scratched or dirty CD or weak/ faulty CD/DVD Drive. Try to clean the CD with a CD Cleaner or mild glass cleaner using a soft lint-free cloth and remove and smudges etc. Better if you try another CD. Else, clean the lens of the CD Drive or replace it temporarily with a working CD Drive for installation.Hope it helps! Good Luck! Thanks for using Fixya!CreativeTECH
Sep 30, 2011 | Intel D865GBF Motherboard
I tried turning my GX60 into a dual-boot and didn't do the partitions right. Sort of put 2 OS in one partition. Now it won't boot and it gives me readings of Drive C: can't be accessed or...
I think that the operating has gone corrupt and needs to be reinstalled. First, make sure that your PC can read the hard disk in BIOS (at boot up, press F2 to enter BIOS and check "Drive Configuration). You should be able to find the hard drive (as well as CD/DVD ROM) here. If not check the hard disk cables etc. At boot up, you may also press F12 for Boot Menu and select the primary hard disk for booting up the PC.
Secondly, boot the PC from CD ROM, Delete the partitions and make fresh partitions for installation of the operating system. You may also add the hard disk of your PC to another PC (as slave) and delete all the partitions from the operating system and make fresh partitions. Place the hard back into your PC and proceed with installation.
CreativeTECH
Sep 22, 2011 | Dell OPTIPLEX GX60 Motherboard
I own eMachine Notebook e525 and it won't read any disks. I have tried multiple disks such as music cds, installation cds and video dvds. None of them read or open. There isn't even an icon for the...
> there is no icon for the CD-drive
Probably means that either:
* no electrical power is reaching the CD-ROM drive
* no "data" is being transferred to/from the drive
* the electronics inside the CD-ROM drive have "died"
Check the "power" and "data" connectors.
If necessary, replace the drive with a new CD/DVD reader/writer.
Jun 20, 2011 | E-Machines emachines (emachinees) CD-ROM...
Something happen and now my laptop will not play my dvds, it saids can not read dvd
are these original dvd?
are the data or video?
does it read cd?
if reads none may be dead drivers or dead drive
if reads data or cd & not video check app
if reads cd & not data or video check corrupt drivers
scan for virus
check system drivers - may be corrupt
check application configuration drive default setting if you have >1 dv drive, may have changed it
Oct 23, 2010 | Lenovo ThinkPad T61 Notebook
Unable to load any game on my computer, the CD drive is showing every file on the CD but after 3-4% of installation setup the error reads unable to read, the same CD is working in other computers, do I...
Since the disk works "elsewhere", it's probably your CD-drive that is faulty. Spend $40 to replace it with a brand-new CD/DVD reader/writer.
The only other possibility is "bad" RAM on your computer's motherboard -- but you would be seeing other symptoms when using your computer, if this was a problem.
Jun 24, 2010 | Lenovo IdeaCentre K210 Intel Desktop...
I can't find the driver of my cd-r king pc camera model VC2P
Try an online search for king PC camera drivers and see what comes up, or go to the manufacturer site and look for driver downloads, that should solve the disc reading issue, however if your drive can't read it, maybe the disc file has become corrupted or your optical drive is failing. Also go to my computer, drive C, programs folder and see if the camera software is in there, chances are you can reinstall it from its original folder.
Feb 03, 2010 | Logitech QuickCam Messenger Web Camera
Windows xp instalation stpos givibg a blue screen in aspire m5640 desktop
Windows Xp installtion give Blue Screen of Death when XP tries to installed devices driver during installation or when the cd is corruptted and cannot be read in graphical mode installation or when the hard drive is corrupted with Bad sector.
Get a new windows XP CD and configure your system BIOS to default setting ( load optimal settings) and configured for IDE drive configuration to compatible mode or disable mode if you are using SATA hard drive.
If problem still occured, get "Bad sector recovery pro" and try to repair the hard disk.If the bad sector are unrecoverable then change the hard drive.
Sometimes, faulty RAM also give blue screen too. Check your RAM too.
Dec 19, 2009 | Acer Aspire m5640 PC Desktop
Canon PowerShot SD600 Digital Camera Logo
154 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
