Question about Palm Treo 650 Handheld
Palm treo 650 verizon phone
Bought this phone used on ebay. is a 1-year extended warranty a good idea? or is the phone likely to be fine anyway?
    Master:
  • 555 Answers
A warranty is only as good as the company behind the warranty. If your seller is a reputable one, the warranty can come in handy in the next year. SquareTrade, for instance, is a good eBay warranty vendor.
Posted on Apr 22, 2008
Hi how to unlock my palm 650 to used outside of USA
You can use the Unlock code to Unlock Your Palm-One Tero 650 model Phone,You can get the Unlock code from here
Wickedunlock and follow the instructions and Unlock it step by step..
Palm One Treo 650 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Palm One Treo 650 mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Treo 650 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Palm One Treo 650 with an ACCEPTED SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application",
3 - Type on Virtual Keyboard *#*#CODE#,
4 - Select with PEN "Numer" and Palm One Treo 650 will show that it's unlocked now!
or
1 - Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
2 - Enter the Unlock Code we send to you.
or
1. Remove Palm One Treo 650 battery, unplug cable,
2. Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
3. 'Sim not allowed' is displayed, click OK,
4. Go to the dial pad, and dial *#*#CODE#,
CODE: The unique unlock code for your Palm One Treo 650.
ACCEPTED : We mean, to use a sim card from the network your Palm One Treo 650 is locked to.
NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Palm One Treo 650 is locked to.
Jul 10, 2011 | Palm Treo 650 Smartphone
I can receive text messages but cant send them
contact cricket and get there messae centre number of them, enter this into the option on your message settings, also get them to send you a sim update and also a gprs message update this will sort all your problems
Dec 30, 2008 | Palm Treo 650 Handheld
How do I export contacts from a Palm 650?
First thing what is your new phone you using now?
If still the same palm operating system,what you need to do is just 1.export your contact from your palm desktop.After that you create a new ac for your palm desktop then import the file you export just now to the palm desktop again.If you are using windows mobile repeat the number 1.then go to your active sync user ac and import from the file you export just now.
Dec 28, 2008 | Palm Treo 650 Handheld
Not receiving some of my text messages
I also have a Treo 650 that works flawlessly. I'm on AT&T and sometimes a message gets delayed but I don't think I've ever missed a message. I would believe it is the verizon network. It could also be effected by sunspots and the part of the world you are in.
good luck
Nov 14, 2008 | Palm Treo 650 Handheld
Palm Treo 650 unlock code needed, used to be with Verizon
yes we can unlock just join me on yahoo id : cellularhut_rajan
Oct 30, 2008 | Palm Treo 650 Handheld
Help please
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
Mar 17, 2008 | Palm Treo 650 Handheld
Please help!!!!!!
The phone may not be compatible with cingular service.
Removing (unlock) subsidy lock on Sprint Treo 6500
If you are a Verizon customer with a Verizon account and the Palm is a Verizon labeled phone, the support people will be able to assist you with transfering the phone to your account.
Since this is a Sprint labeled and logoed phone, there may be a bit more work to get this locked to your account. You will need to have a Verizon technician assist you by calling their support line and explaining your situation. You will need to verify with them that the phone has a clean ESN and they will ask you for that number to check. They will be able to get you on their network if the ESN is clean and your account is in good standing. There are a number of sites and blogs dedicated to this very issue. Just search for your phone on the internet and you will find them and what to do to have your phone switched over.
As far as changing the splash screen from Sprint to Verizon, that requires software and understanding where the image files are located. This is not a task for the novice. Again, when you look through these sites, you will find the information on how to change these items, how to back up your phones data dump, and how to read the different categories these items are located in. Be careful...you can destroy your phone if you are not careful.
Good luck.
Mar 10, 2008 | Palm Treo 650 Handheld
Palm treo 700 wx won't charge
Verizon 700wx:I had the same problem. With little or no movement, the phone would go from charging to not over and over. At home with it perfectly still it would charge maybe 1/4 in 6 hours. Same problem with 3 different chargers. With the battery out, I dipped a Q-tip in rubbing alcohol squeeze out excess and jammed it into the charging port on the phone. Put the battery back in and oh **** nothing. Took it back out and let it dry for a few minutes and were back in business. No more charging problems at all.
May be a little risky, but warranty was up and what did I have to lose. Anyway good luck!
Feb 16, 2008 | Palm Treo 650 Handheld
Palm treo 650
The 650 seems to have a delicate headphone/mic jack. Dropping the phone, even gently, seems mess up that jack. I returned my first treo 650 as defective, and got a new one. The same thing happened to my new 650 after I simply compressed the phone in my breast coat pocket by holding my mail against my chest.
I can't get a new one because the replacement treo comes with no warranty of any kind. :(
My advice would be to find a PDA/phone repair service to repair the jack or diagnose the problem if it turns out not to be the jack.
Jan 12, 2008 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
55 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
