Question about Sanyo DS25390 TV
Tv won't go past channel 69 - Sanyo DS25390 TV
Why will my rca trflat not go past cannel 69
Hi there. Maybe your TV is not equipped for S channel reception.
Channel 73 falls into the S band; (21-69 is the normal UHF band.)
However in most cases, you must choose in wich band you scan your channels; (H, or S) I cannot imagine that this modern TV should not be equipped for S channels. Try manual channel search, where you'll probably find this possibility.
Oct 03, 2014 | Televison & Video
Have durabrand dct1303r tv that will not go above channel 69
you durabrand tv stay in air or tv section . so tv only showing 1 to 69 channel. you need to going to menu setup change air /tv to cable. that should be catch all channel back. good luck!
Sep 06, 2012 | Durabrand Televison & Video
Tv will not change channels past channel 2
Hello
Check if any microswitches on its front panel ahs been strucked. Replace all the microswitches at the same time. it won't cost more.
Mar 03, 2012 | RCA Televison & Video
I have an old toshiba projection tv and i'm trying to program the channels but it won't go past channel 69 how do i get it to go higher. i've tried auto programing and that does'nt work.
In the menu check to make sure set is set to "cable" band and not "air"; 69 is as high as it will go if in air band.
Select CATV and not AIR.
before you rate this information let me know what you find or if you have questions.
SD TECH
Aug 05, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
I tried auto programming my tv but I can't go past channel 69. All other tvs go up to at least 99. When I try to manually program 99, the remote will only input a 9.
There are only a possible 48 channels available in the UHF bands IV and V; 21 - 68. Some Continental TV's still use band III; 1 - 20
Are you sure you are not getting confused by programme numbers which can go up to 99 and AU etc.
Jan 04, 2011 | Panasonic CT-27E13 27" TV
We have an older model tv and can't figure out how to get the channels to above 69
Channels 2 to 69 are over the air - Antenna - channels.
Channels 2 to 125 (some duplication) are Cable channels.
There should be a way to switch your TV to Cable channels.
If it's really old there may be an Antenna/Cable toggle switch on the back of the TV.
Most newer TV's have a way to get a Menu that you can use to switch between Antenna and Cable. Check on your remote control.
If neither of those you'll probably need to buy a new TV.
Jul 20, 2010 | General Electric JASAV22730 Freeview DTV...
I can't go past channel 69 and I need to go up to at least channel 73
how old it the t.v. - most t.v.s are at least 181 channel compatible..hodge-podge words..in lay terms you have to have the capability on the t.v. to support X nbr of channels...also check to see if you have the menu set at cable or air...setting needs to be on cable
Jul 07, 2009 | Emerson EWF2004 20" TV
I have a Samsung 27" TV and need to set it on channel 73 to get a picture from my Satelite Dish. The highest channel the tv goes to is 69.
Set the TV to cable tuning mode and use that channel 73. You have it set for air now so it can only tune to channel 69.
Apr 26, 2009 | Samsung TXN2771HF 27" TV
Does tv go higher than channel 69
In 1998, UHF-69 was highest channel. you need that TV which has today's technology.
May 29, 2008 | GE Televison & Video
Switching from TV to CATV
it sounds like the tv is already in cable mode, and that it is a older tv. some older tv's will only tune in so many channels. yours going up only to channel 69. if you have the remote for this tv, try punching in channel 73. if it doesn't tune in, then the tv will not recieve channel 73.
good luck
wg
Feb 05, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Televison & Video Logo
256 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
