Question about Sewing Machines
Stops sewing just started about a week ago. Was sewing for about 2 hrs when it just stopped. pressed presser foot and just made humming sound. turned off and on several times. Would run few minutes then stop. Finally stopped. I turn it off and left it for 10-15 min. Then ran again. The next time I used it it did the same thing.
  • Anonymous Mar 12, 2014
    I took the machine out of the packaging and read the first part of the instructions. I plugged in the machine to test the foot pedal. It ran for about 2 seconds and then stopped. I turned off the machine and turned back on again. the machine will not run, only makes a humming noise. It is malfunctioning? Can it be fixed.
    Problem Solver:
  • 7 Answers
Your machine is over heating. Sometimes it may also get stuck and just continue to sew and you will have to unplug it. Mine would also flash to just a blue screen. It had a pinched wire on the inside that caused it to over heat.
Posted on Apr 22, 2008
E 1 error message
Make sure you lower the presser foot before continuing the operation.
The foot controller was pressed (or the start/stop button
was pressed if the foot controller is not connected)
and the reverse/reinforcement stitch button
was pressed while the presser foot was raised.
Mar 01, 2014 | Brother CS6000i Computerized Sewing...
Cant get machine to embroider
there are three positions the presser foot can sit in. Up and down are the same on any machine. The 7570 has an in-between position for embroidery. Lift the presser foot and the lower it slowly while pushing gently. It should stop about half way down. The embroidery foot pushes the foot into the down position with each stitch allowing the fabric to move easily to the next stitch.
Jan 29, 2013 | PfaFF Creative 7570
Pfaff ambition 1.0 sewing by itself
sounds like there a problem with the motherboard giving the wrong
commands. the machine definitely needs to be checked.
Sep 11, 2012 | Sewing Machines
Husqvarna Designer 1 noise and thread breaking issue.
I would be willing to bet that there is a piece of thread wound around one of those pieces below the bobbin area. Get your magnifying glass out and have it a good long look. When you find thread... use tweezers to pull it out.
Sep 09, 2012 | Husqvarna Sewing Machines
I can't start to sew on my 830. The foot control is recognized(the start/stop button light goes off when I press the foot control), but does not make the presser foot come down. It worked 15 minutes ago...
If you lower the pressure foot before you press the foot control does it sew then? If so, then some how in your setting menu you auto pressure foot setting has gotten turned off.
Apr 23, 2011 | Bernina Artista 180
Presser foot stopped working I turned
Did you connect your machine then press the foot control before you lowered you presser foot? I have a CS6000 and that is what E1 means on my machine. You did not put your model number in so I don't know. You can look in your manual or go online to www.brother-usa.com and look it up for your machine. Try unplugging and plugging it in again, but put your presser foot down then step on your foot pedal.
Oct 04, 2010 | Brother Sewing Machines
What should I do when error message E1 hapend
An "E1" message appears on the panel. Description: The foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) and the reverse/reinforcement stitch button was pressed while the presser foot is raised.
Lower the presser foot lever before continuing the operation.
Mar 02, 2010 | Brother CS-6000
Sewing Machines Logo
137 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
