Question about HP Business InkJet 2800 Printer
HP Business Inkjet 2800 Printer will not print 11x17
I just got a new computer and upgraded to Windows 7. Now my HP Business Inkjet 2800dtn won't print custom size documents, specifically 11x17.. I tried in Acrobat as well as Photoshop. I made sure my preferences in the printer were set to the size I want, but it still only prints 8.5 x11.
Nubar
  • 51 Answers
SOURCE: HP BUSINESS INKJET 2800 SERIES OUT OF THE BOX WON'T PRINT BLACK
Usually this happens when the black cartridge is out of ink or when it is damaged.
Try to print with a new black cartridge
Posted on Dec 12, 2008
guide2u
  • 461 Answers
SOURCE: printer error in my hp business inkjet 2800 printer
not sure what error you are facing, but below link might be able to help you on the appropriate actions to take...
http://etech.maiila.com/hp-color-laserjet-2800-all-in-one-printer-series-driver-manual-and-software-download-including-for-vista
good luck
Posted on Feb 10, 2009
  • 4 Answers
SOURCE: HP Bus Inkjet 2800 won't print 11x17 with Vista
Many people had a similar problem with the Color Inkjet cp1700 B-size printer.
Vista Patch for cp1700 Printer - Fixes Duplex and Large Format Printing
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=2916&
General page with links to the cp1700 and other printers as well.
Vista Duplex Solution - Back Page Upside Down
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=43
and
http://www.vistax64.com/vista-print-fax-scan/172813-cannot-print-wide-format-hp-cp1700-2.html
Another solution that worked for some people was installing the hp deskjet 9800 printer driver.
It appears what you need is a patched .gpd file for the BI 2800.
Try emailing Bob Headrick, who has done these patches. (Thanks Bob)!
Be sure to put Vista and Large Format Printing 11x17 in the subject line.
bobh@mvps.org (or see his profile for email address)
Bob Headrick, Microsoft MVP Printing/Imaging
You'd think between HP and MS, they'd have this working right out of the box.
Did they think people would buy a B-size printer so they could hook it up to Vista and then not want to print mainly B-size documents?
They would have had happier customers if they would have included B-size support but left out A-size!
Amazing!
Good Luck
Posted on Jul 20, 2009
nalin_elliot
  • 224 Answers
SOURCE: reset hp2800
Hard Reset
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds then replug the power cable to the wall out let and then to the printer.
Power Drain
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds now press and hold the power button on the printer and replug the power cable to the wall out let and then to the printer after the power cable is connected you can let go off the power button..
Posted on Aug 11, 2009
  • 192 Answers
SOURCE: HP Business Inkjet 2800 firmware PMR2006A
Unfortunately the page you are trying to reach is not a valid page. As an HP tech I searched internal for a firmware update on that model and there isnt one available.
Posted on Jun 05, 2010
2800 HP business inkjet won't stop initializing after installing print heads
BECAUSE IT CANNOT FIND THE PROPER HARDWARE AND INK. TRY TO PRINT A TEST PAGE, AS WHEN YOU FIRST TEST IT.
Jun 18, 2015 | HP Business InkJet 2800 Printer
Setup & Install for HP Business Inkjet 2800 Printer series:
http://bit.ly/1h83Ey5
Apr 19, 2014 | HP Business InkJet 2800 Printer
When trying to print an 11 x 17 word 2010 document that displays properly on the screen only a portion approximately 8.5 x 11 prints out of my 3 month old HP business Inkjet 2800 printer.
It may be that an updated driver is needed; that would be available from the HP website. You should be able to manually set the printer via the HP user software that came with it although it seems that Word should be able to do that automatically.
Sep 09, 2010 | HP Business InkJet 2800 Printer
and
Amazing!
Good Luck
Jun 05, 2009 | HP Business InkJet 2800 Printer
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
Hp business inkjet 2800 will not print cyan although have replaced cartridge and run all onboard diagnostics. hp troubleshoot shows no problem yet printer will not print
You say you replaced the cartridge but did you replace the print head. If you fully lift the cartridge cover you will see a row of print heads. The Cyan print head is C4811A. Try replacing this.
or
If you feel lucky you can run the print head cleaner diagnostics. The print head may simply be dirty or clogged.
Apr 04, 2009 | HP Business InkJet 2800 Printer
Dec 12, 2008 | HP Business InkJet 2800 Printer
Troubleshooting
reinstall ur printer software andb then check
Oct 28, 2008 | HP Business InkJet 2800 Printer
HP Business InkJet 2800 Printer Logo
242 people viewed this question
Ben Johnson
