Question about Canon PowerShot A95 Digital Camera
Will not work at all
I was using the camera and a red indicator came on so I recharged the batteries and put fresh ones in. Now it won't turn on at all.
Problem with the contact of the battery probably. check and may be try to wash it with coton buds and a little bit of alcohol.
bye
Posted on May 26, 2008
Camera says batteries low, replace
Make sure you are using fresh batteries when you are replacing them. If you are using rechargeable batteries, let them charge until the indicator light on the base unit turns green. If the indicator light on the base unit flashes red, the batteries are no longer good.
Cheap batteries form dollar stores (Sunbeam, or store brand name) do not last long, and digital point and shoots eat up those types in a few uses. Best to use Duracell or Energizer batteries for Cameras. They dont have to be Lithium, or digi camera specific batteries. Those are expensive and unnecessary. Basic Duracell or Energizer will do.
Feb 03, 2015 | Sanyo Vpc-s1414 14 Mp Digital Camera Vpc S...
Change the batteries message keeps appearing even with fresh batteries. The camera turns on then immediately turns off What's up?
This actually a really common problem among Canon point and shoot cameras. There are a couple of methods that have worked well for others.
1. Open the battery compartment and remove the batteries. Then take a regular wooden pencil and place the eraser end down onto the battery contacts. Rotate the pencil to remove any corrosion. Sometimes a lack of proper battery contact will result in the low battery indicator.
2. Take a toothpick and wedge the tip under the battery contact and break it off. This will put more pressure between battery and contacts.
You can also try installing 3rd party firmware at http://chdk.wikia.com/wiki/CHDK_in_Brief
This is a bit technical and will probably void your warranty, but might be worth the try.
May 08, 2011 | Canon PowerShot A460 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Help me!
The most likely problem is the batteries. You don't mention which ones you have - if they're rechargeable, charge for 10 - 15 hours even if the charger indicates a full charge. If those rechargeables are a couple of years old - replace them. If using non-rechargeable, be sure they're NOT "heavy duty" or "super heavy duty" - those are useless, for toys. Get fresh alkaline batteries.
Dec 12, 2008 | Kodak EasyShare CX7330 Digital Camera
Problems with camera
Hi everyone,
I found you because 10 minutes ago, my camera exhibited the same behavior as all yours. All of a sudden, the red and green lights started blinking on and off and nothing worked. I just tried switching batteries and the camera is working! I am using a couple of RCR-V3 Li-ion rechargeable batteries, which I purchased on Ebay three months ago. Thought I'd pass it on.
Take care,
Rosane.
Jul 17, 2008 | Olympus SP-350 Digital Camera
Battery problems
The camera is probably defective. Warranty?!?
Unless you have put the batteries in wrong or not used fresh ones!
Apr 24, 2008 | Kodak EasyShare CX7330 Digital Camera
Wont switch on
Some cameras have a bettery setting in the menu. You need to make sure this setting is set to the type of batteries you are using. Usually when you use akaline batteries and even if you put in fresh batteries but still get the low battery indication then your camera is set to rechargable (Ni-Mh). Ni-Mh has more power to it then alkaline so this is why you get the low indication.
Feb 11, 2008 | Samsung S1030 Digital Camera
Red light flashes and LCD turns off and on
A quick test would be to purchase a set of Duracell Ultra Digital batteries and try them. They won?t last for very long; however, if they make the red light go away then you problem is either the batteries you are using or the charger. More often than not its going to be the batteries so we?ll start there: Check your batteries, you should be using Nickel metal hydride (Ni-ME) that are rated at 1450 (I use 2500) mAh or better. If the batteries are more than one year and you?ve used them a lot then its likely the batteries just aren?t holding a charge anymore. Purchase a new set or borrow a working set from a friend. Charge them in your charger and try in your camera, if the red LED goes away use the batteries till they need charging again. Charge them in your charger and if the red LED stays off then the batteries were the problem. If the red LED returns then try charging your batteries in someone else?s working NiME charger. Put them in your camera and if the red LED goes away then your charger is the fault.
Jul 23, 2007 | HP Photosmart 945 Digital Camera
Battery Low with NiMH (won't turn on) OK with Alkaline
Not the camera obviously - works OK Replace the NiMah batteries- get several sets and keep one set in the bag charged with one set in the camera. You may be able to 'refresh' the original batteries by putting them into a small flashlight and running them until the bulb goes out. This discharges them completely- then recharge. It is said batteries have a 'memory' so that a battery that is down say 50% and recharged will only recharge that 50% and the other 50% is lost for use. So you have to flatten the batteries completely
May 29, 2007 | Samsung Digimax A7 Digital Camera
Olympus FE-115 : wont turn on..turns iself off!!!
I had the same problem and i called up cutomer support on 1300 659 678 (Australia) and they said that the problem may lie in your batteries. It was advised that you use Lithium batteries, and to avoid use of Alkaline, since they dont have the required power to operate the camera which is why it turns off right away. As to what type of rechageable batterires to use i am not sure, i think it was Nickel-metal-hydride (NiMH) batteries. Hope this solves your problem.
Sep 10, 2006 | Olympus FE-115 Digital Camera
Canon PowerShot A95 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
