Question about Craftsman 25cc Gas Line Trimmer
Gas leaking out of center hole on gas cap sears weed trimmer 358795150
I had same problem and got a replacement cap at a small engine shop. Seems there is a baffle in the cap to allow the tank to vent and to close off to prevent fuel leaking. Appears rubber baffle deteriorates over time.
Posted on Apr 24, 2012
  • 4 Answers
Check to see if there is a gasket required for the gas cap or if the gas cap is missing the inside plastic part. refer to operation manual
Posted on Jul 21, 2010
  • bicedf
    bicedf Apr 24, 2012
    I jusst replaced my cap at a small engine shop--seems there is a rubber baffle in the cap that allows the tank to vent at center hole and to close off to prevent fuel leaking. Rubber deteriorates over time.
I replaced my primer bulb on my craftsman weedeater an am not sure what line goes where on the primer bulb can you help also not the gas leaks out of carb hole where
In regards to which pipe goes where, it's simple. If you pump your primer bulb with the pipes off, one side will suck and the other side will blow. The suction side will link to the outlet on the carb. The blow side will link to the return to tank. The fuel line with the filter on it will link to the inlet pipe on the carb.
May 12, 2016 | Craftsman Garden
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Poulan 2500 weed trimmer gas cap covered with plastic to prevent leak. Will this cause problem
I fear it will because the fuel tank breather is in the cap, you will create a vacume in the tank and the engine will die out.
Mar 10, 2013 | Garden
My weed wacker is leaking gas out of this little hole beneith the exhust and ii leaks badley
Fuel line coming out the tank has compressed and is letting fuel leak out
Jun 11, 2010 | Troy Bilt Tb70ss Gas Trimmer
WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Gas line needs to go thru buttom of gas tank on sears weed wacker
Take your old line to a lawn mower parts store, ask for a new gas line of the same size. I would buy about a foot long. Push the line in the tank down into the tank(doing this with the tank empty), remove gas cap, turn upside down, a filter and your old line will fall out. Press the new gas line through the hole, push enough through that it comes out of the filler hole, place filter onto the new line, drop into tank, cut off excess and reattach to the carburator.
Aug 06, 2009 | Craftsman 25cc Gas Line Trimmer
Hard starting will not restart after warmup
Try this: The next time you run the trimmer, and it begins to die, loosen the gas cap. It should start running again. This means that the gas cap is clogged. Clean the holes out of gas cap, or buy a new one. (If this doesn't help, give a more detailed explanation the next time.)
Jim
Jun 05, 2009 | Husqvarna 28cc Gas Line Trimmer
Weed trimmer
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Sep 02, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Craftsman 25cc Gas Line Trimmer Logo
2,112 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
