posted by WILLY B 60 on Apr 22, 2008
THE PROUBLEM IS MY TV JUST STARTED WORKING BAD ALL OF A SUDEN. THE PICTURE HAS WAVES TOWARD THE TOP OF THE SCREEN. THAY ARE GREEN. AND THE PICTURE IS DOUBLE, AND BLURY.I TRYED ADJUSTEN THE CONVERENCE BUT IT GOT WORSE. CAN YOU TELL ME WHAT I NEED TO REPAIR THE PROUBLEM. AND THE PART DISCRIPTION AND NUMBER. THANK YOU
2 Other Users Have The Same Problem
Comment by liber8d, posted on Apr 30, 2008
I am having the same problem. All of the sudden, the top of the picture was a bit curved and the colors look like they are separated. In the center it is fine. If I squint it's even better.
Comment by rwp1, posted on Apr 27, 2008
we are currently having the same problem with our 65 in Rear Projection HDTV-Ready television. Same exact problem
Best Solution
posted on May 24, 2008
If you guys do not have hand soldering skills or know how to use a multimeter, I would suggest to replace the whole assembly.
If you know how to solder you can just replace 2 ICs that are mounted on the big black heatsinks and possibly 1 or more resistors.
Click here to find the entire assembly for your TV.
The link provided is for parts for the AV-56WP74 model ONLY. For the 65 inches; you should contact the vendor and provide the correct model number.
Good Luck.
Good Luck.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for JVC AV-56WP74 56 in. Rear Projection
Email this problem
Email this problem
Can you Help with these Projection Televisions problems?
JVC AV-56WP74 56 in. Rear Projection...
JVC 56in. is broken
JVC 56in. is broken
My rear projection tv isbroke... Answer This...
52 inch jvc projection tv, cant...
i cant get any movie to fit the... Answer This...
jvc projection tv
jvc projection tv
I have a 56 projection tv that... Answer This...
colors are out of line
the red wont line up with the... Answer This...
Repair Service
Find Projection TV Repairman Near You:
