Question about Fisher and Paykel WL26CW1 Top Load Washer
Washer will not spin there is water on the floor and has a fault code of 130 it is fisher+paykel brand model numberWL26CW1
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Error Code 130 means your fault is called Single Rotor Position Sensor Error.This component is attached to your motor which is underneath your machine.What concerns me is your machine is leaking.Did the Error Code appear the same time your machine started leaking?The reason I am asking this is because the water could have damaged the rotor sensor.Is the water leaking underneath the machine?Please reply with additional information and I can help you rectify this fault.
Posted on Jul 20, 2010
Error code 130
IF a Fisher and Paykel, see this link:
http://ths.gardenweb.com/discussions/2427379/fisher-and-paykel-gwl11-error-code-130
You need to list brand (if not also model number) when you post white goods questions. Codes are specific to a manufacturer.
Mar 04, 2015 | Washing Machines
My fisher and paykel smartdrive wont agitate or spin but it pumps the water out it , when i spin the drum there is a bumping sound. can i get into the drum part to see if anything has gotten inside?
That is fault code 130
130.(10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
Jul 31, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel GWL 15 Rotor Position Sensor
Does It just shake bowl left & right, it will soon give you fault code 56.
Well its a board problem you will need to get technician to fix this board, three resistors(R129,R130,R131) need to be changed for a 1MegOhm resistor.
Jul 08, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fault 130 Cold water valve cycling on and off rapidly. On spin, pump cycles on and off rapidly.
Hi just read your posting Now error code 130 means you have a Single Rotor Position Sensor Error.That means the Rotor Sensor which is attached to your motor is faulty or the wires to it are broken.The other fault it could be is the motor controller.The only way to test the Rotor Sensor is with an RPS tester.I can help you test the continuity of the wires that go to the Rotor Sensor if you have or can borrow an electrical test meter.If i had to guess which part is faulty, It would be the Rotor sensor.Hope this helps and please reply for further help.
Jun 06, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
My fisher and paykel washing machine keeps flashing a fault code
needs a new Rps sensor , 130 is a fualty Rotor postion Sensor
Jan 24, 2010 | Fisher and Paykel IWL12 Top Load Washer
Intuitive eco Fisher & Paykel
try google search for the actual model and fault code
Jun 04, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel WL26CW1 Top Load Washer Logo
847 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
shaun taylor
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
