Question about Dryers
I have a Kenmore 70 series gas dryer. When I push the start button the dryer starts up, but as soon as I take my finger off the start button the dryer stops. If I hold down the button the dryer runs for about 5 seconds and then shuts down. I have checked continuity of switch and its good. I also took it apart and checked belts. Also checked continuity of timer motor and door switch. My original trouble was that when I pushed the start button the dryer made a noise and didn't run. I thought it was belt . After taking it apart to check belts it started this new trouble. Thanks Debbie
  • twstedpair Jul 20, 2010
    What part of control panel should I replace. Could trouble be with centrafug switch?
    Thanks
    Thank-you for your help.
    Top Expert:
  • Dryers Master
  • 81,400 Answers
The most common cause for a problem like this is a motor that is plugged with lint or has a bad motor winding.
If the motor has a bad winding it will not stay running once the start switch (or timer) is released.
You need to take the dryer apart and see if vacuuming out the motor solves the problem. If it doesn't, it's recommended you replace the motor.
Also make sure the drum spins freely and is not binding causing the motor not to start.
If all checks ok with the motor and drum there may be a problem with the start switch but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
If everything looks good replace the dryer drum drive motor.
Posted on Jul 20, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Debbie as you have already checked the door switch, timer motor then the issue seems to be either with the belt only don’t think its anything else as when you push it hold the start button then it runs, so its more likely the belt that should be checked and replaced if its bad. Please check this video on how to replace the belt in dryer. Also check the tensioner pulley and replace it if it’s bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
    I checked the belts already. When I push the start button I have to hold it down to keep the dryer running. When I release the start button the dryer stops.
    thanks
  • Rylee Smith
    Rylee Smith Jul 20, 2010
    Then take the control panel off and blow air with the help of hair dryer if still the issue is not resolved then the control panel should be replaced.
When you push the "push to start" button, the
I would say change your Start button should take care of the problem.
FIRST Always unplug the Dryer before doing any work on it.
Good Luck
Dec 26, 2010 | Kenmore 62982 Electric Dryer
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
I have a Kenmore Series 70 dryer wont start, just hums
Check for correct voltage at the terminal block on the back of the dryer, where the power cord attaches to the dryer.You should be getting 220/240 volts, check by way of a voltage tester.
If the voltage is correct, then could be the motor capacitor or the motor itself, or start button?
Good Luck !
Feb 07, 2010 | Kenmore 63942 Dryer
Kenmore Dryer 70 Series. Push switch in and just a little clicking noise. No motion. Took top & front panel off, belt appears to be fine. Suggestions Please??
set timer push button in for dryer to start dryer did not start, timer is working and door light is on,what could be the problem
Oct 17, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore 70 series dryer has power just wont start when push the button is it the start switch?
could be the start switch or it could be the safety switch in the bottem of the dryer that turn the dryer off incase the belt brakes.
Oct 02, 2009 | Kenmore 63942 Dryer
Kenmore 70 series dryer doesn't turn
your dryer motor has just gone bad,it is no longer strong enough to turn over-sorry-mike
May 04, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas dryer. 70 series
sound slike something fell down there and is jamming the blower from turning. if the filter is ontop of the unit, remove the 2 phillips located under where the filter pulls out from. and the n remove all the screws on back panel youll see ( down the left side of unit ) the filter houosing, its secured by 3 5/16 screws toward the bottom portion of the housing, simply unscrerw and wiggle out, then remove the debris, and reassemble.
if the lint screen is located inside behind door, eitehr remove the bottom accesss panel or pop the top(with a screw driver approx 3 inches in from ither side of main top relaes the clips) the lid tips back revealing 2 screws holding front panel to the unit, after removing you will see the filter housing, still mounted by probalby 3-4 screws, remove the housing and retrieve the debris that has fallen down there
Apr 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
