Question about Maytag Washing Machines
My washington machine water smells horrible, but not the water in the rest of the house. It all enters the house through the same pipe from the municipal water supply. Could there be something within the washing machine affecting the water?
    President:
  • 670 Answers
You probally have a front load washing machine. There is probally mildew in the wash tub & discharge hoses. Try washing an empty load with a hot water and a cup of vineagar and see if that helps with the odor. If it does, then repeat this once a month.
Posted on Jul 20, 2010
When washing iwe get a horrible smell like bad
Is this a newly installed machine?
That smell would normally be associated with drains, indicating that the outlet from the machine to the drain is not correctly fitted with a trap.
Mar 25, 2010 | Indesit W 123 Front Load Washer
The water is coming out smelling horrible. What
try running a pot of vineger through it and then a pot of water before you make coffee again.
Dec 21, 2009 | Coffee Makers & Espresso Machines
I bought two of these washers and they both have this problem. The worry is not only the horrible smell but the fact that these washers are not killing germs but rather creating bateria and mold.
have teck come and clean out filter, mold, etc behind seal, then clean about 1 time a month by running wash cycle with hot water, no clothes and 1 cup bleach, always leave door open til washer drys, careful if small children or pets are in the house they may climb in
Nov 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Foul odor when I start a load of laundry
Obviously this problem exists on this manufactured machine (Cabrio). It has to do with the design of the machine and the HE detergent required to be used. We are on city water and the smell is sewage gas. Hence, do your whites last with lots of Clorox/bleach, cause the detergent isn't strong enoug to kill the bacteria growing in the pipes. That being said, P
Jul 12, 2009 | Whirlpool Cabrio WTW6600SBK
I have a Kenmore washing machine and so far I haven't have a problem with it...the problem is that most of the time when we do laundry a horrible sewer smell comes out. It doesn't seem to be coming from...
You are probably correct with the idea the sewer smell is not coming from the washer but rahter then drain line. Was this recently installed or has a slow drain down the pipe? There is suppose to be what is called a P-trap installed in the drain pipe to restrict the gases from coming back into your home. Check the drain line. If I can help further, I am here. Eric Campion
Mar 03, 2009 | Washing Machines
Horrible Water Odor
Does the old house have any time of whole house water filter or water treatment system? Usually with sulfur water it is necessary to treat the water. It can be nasty. good luck
Jan 19, 2009 | Franke 900 Gold Basket Strainer 900
My washmachine smells horrible. My whole house it starting to smell like it. What do I do??
there is nothing in a washer to smell - just stainless steel, rubber and plastics!
check the following:
are you using liquid detergent? if so after extended use, the machine smells like drains. put on the hottest wash with no clothes and smell will go. revert to using powder.
check there is a water barrier between the drain hose and your main drain. if not, the smell of your sewer will come up thro the drain hose.
is the drain connected to a spigot off the sink trap and do you have a waste disposal unit? these stink and unless you again have a water barrier the smell will come thro the drain hose
Jul 21, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Neptune t.l. washer has a horrible odor that we have not been able to fix, either with bleach & vinegar solution nor with Electrasol lemon scent dishwashing powder, as has been suggested to us. This...
if you use liquid detergent for a long period this will cause a nasty smell and it leaves a horrid slime in pipework etc. if so, put on a boil wash and change to powder.
also, make sure there is a water barrier between the washer drain pipe and your house drains
Jul 11, 2008 | Maytag Washing Machines
Problem with whirlpool front loader
Your water mixing valve is letting water in the machine between cycles. That is the valve that the hot and cold water hoses connect to in the back. Replace that valve to stop the water build up. Run a periodic cleaning cycle with a generous amount of white vinegar to rid the smell. Or you can buy a prduct called Affresh from a hardware store.
Jun 21, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
165 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
