Question about Avanquest System Suite 9 Professional Full Version for PC
I installed system suite 8 professional on my computer. Now my computer will not go past windows xp window..i cant get to safe mode or anything, and lost my windows xp disk. any suggestion?
    Champion:
  • 200 Answers
Try last known good in the menu instead of safe mode other than that you will most likely need the operating system disc to repair or reinstall the system.........if you are lucky you have a backup on the hard drive try hitting the F 10 or F 11 button when you first start to boot up to see if you have a hidden restore on the disk if so it will give you a menu for a restore follow the prompts to repair the computer best to go to a working computer and go to your computers website and look up the manual it has valuable info.
Posted on Jul 20, 2010
My computer cannot start because it says there that ole32.dll is missing, how can i fix this?
hi there is a free download address you could go to if you can get into windows through safe mode .choose /safe mode with networking/ open search engine typewww.dll-files.com/dllindex/d-llfiles.shtml?ole32.if you cant get into windowstry re-covery console from your install disc /type in command/c/drive.then dllole32/enter if this dosen,twork you need to install a fresh set of windows xp pro.
Aug 22, 2010 | Microsoft Windows XP Professional for PC
Wont get past Microsoft Windows XP loading screen on Acer Aspire1
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 17, 2010 | Acer Aspire One AOA150-1126 Notebook
Need to reboot my crashed computer cant get windows xp to reboot
HI how are u, ur Windows Xp is corrupted
Cause :
1. Viruses
2. Computer was not Shutdown properly
3. Some windows File Corrupted
Solution>>>>>>>1.
1. Go to Safe Mode at starting mode press F8.
2. If Computer Go to safe mode successfully>>
3. Go to start >> Programs>> Accessories>>System tools>>System restore.
4. Restore ur computer in privious date.
Solution>>>>>>>2.
1. Insert WIn xp cd in cd rom and restart it.
2. Repair Your win Xp via a Repairing utility.
Solution>>>>>>3
1. VIa a formmating utility U can install a new fresh copy of windowxs.
Thanxs
Mukesh Kumar
Mukesh_ibm@yahoo.com
May 12, 2009 | Microsoft Windows XP Professional
Windows XP Pro SP3 will not boot normal mode
This may be because you have the wrong drivers installed- i reccomend starting your computer up in safe mode and using system restore go back to a past restore point before upgrading to SP3
then update your drivers before upgrading to SP3
i reccomend drivermax.com to update drivers.
Hope i could help
CBZ
Comment if you need more assistance
Apr 27, 2009 | Microsoft Windows XP Professional SP3 Full...
My system restart problem
Sounds like a hardware or heat issue. In safe mode your computer is using just minimum resources. Check the temp of your processor, and make sure all cooling fans are running. You can enter bios and check hardware monitor to see the temps.
Apr 25, 2009 | Microsoft Windows XP Professional With...
Restarts computer in loop at 5-8 minutes of boot
Please try install XP SP3 in safe mode. Then check whether you have the latest Graphics Card Driver. It seems like some driver issue as it reboots only in Normal mode. Since safe mode runs on minimalset of hardware drivers.
Secondly, there may be a corrupt file that caused reboot. Spend a night and schedule bad sector check - Right click on system drive, Tools tab, Error Checking -> Check Now, tick both boxes then Start. It will schedule scan on next reboot. Then reboot to confirm it starts checking HD.
Apr 24, 2009 | Microsoft Windows XP Professional With...
Hello... My Windows XP has the following registry failure (c:0000218) I've attempted to boot up my Avanquest Systems Suite 8 Rescue disk, but it has failed. I can't get into safe mode, etc. Thanks, Paul
Sorry to hear about your trouble. From the error you stated, it seems your SR got corrupted (common with norton/symantec products). The best bet is to try System Restore from Safe Mode.
As for your second problem, here is an alternate way to access Safe Mode (I am assuming you can get into Normal Mode):
  1. Go to START, then RUN
  2. type "msconfig" and hit enter
  3. the system configuration window will appear
  4. among the several tabs across the top, one of them will say "boot.ini", click this tab
  5. there will be a box that you can check next to Safe Mode.
  6. Click Apply, then OK
  7. Restart
  8. Keep in mind that your computer will automaticall go in to safe mode until you uncheck this box.
Good luck and keep us updated!
TJ
Nov 30, 2008 | Avanquest System Suite 8: Windows
Xp blue screen
only solution to this is re-install the operating system...
Sep 11, 2008 | Microsoft Windows XP Professional for PC
XP Pro can't logon
try going to safe mode first,restart pc,press f8,go to safe mode..choose administrator..if that didnt work,install your windows xp,post a reply if that didnt work so i can tech you how to install your xp
Jun 27, 2008 | Microsoft Windows XP Professional With...
Windows Login Password - Cant Safe Mode or Log in as Admin
Hey Steve/Becky - I have one question for you before I fix your problem. When you booted in safe mode, did it give an option of several logons, i.e.- yours and an administrators?
May 05, 2008 | Microsoft Windows XP Professional With...
Avanquest System Suite 9 Professional Full Version for PC  Logo
Top Avanquest Computers & Internet Experts
Alun Cox
Chris Larocque
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
