Question about Campbell Hausfeld Garden
I was given a low hour, 10 year old, CH PW205002LE 6.5 HP gas vertical shaft 2000 PSI/2.5 GPM pressure washer with a Lavor pump. It did not work - no pressure. I found a broken o-ring on the brass unloader valve and replaced it with a ring as close in size as I could find as the part break down doesn't state size. Everything was very clean. I coated everything with silicine grease and reassembled, seating the brass piston? as deep as it would go. I had to press the trigger in order to get the motor to turn over. Wow, great pressure - for about a minute, then something seemed to slip and back to no pressure. Upon disassembly, I found no problem, but I knew the pump would make pressure, so figured the problem must be with the unloader, PN: PM040100AV. I tried a different o-ring as it looked a bit large, slightly loose, and I wondered if the piston wasn't sticking closed initially, then would allow water to bypass. So, I shimmed the spring about 1/8''. The threads on the plastic cap were worn. I had to pull the trigger again to start the engine, and again had pressure. I wondered what would happen when I released the trigger. I soon found out. It blew the unloader cap (PM035150SV)out, along with unloader parts. OOPS, too much shim? Anyway, I found all of the parts EXCEPT the brass cylinder/piston/retainer. It must have hit something and flown somewhere. Now I'm screwed. The Unloader kit PM041390SV is no longer available. Now what? I really hate to throw a perfectly good low hour pump away. Hmmm, there is an unloader kit listed for a 1750 PSI pump. I wonder if only the spring is different? At any rate, if anyone knows where; 1. I can get the unloader kit PM041390SV, or possibly PM041380SV. 2. Another more specific forum or parts source. 3. tips etc. please let me know. I'm gonna go rake the yard now and hope I find it. I'm hoping a dealer may have NOS (new old stock) on the shelf somewhere. BTW, there are replacement pumps listed on ebay for 80 bucks plus 20 shipping and another 10 for a thermal kit. Anyone had any experience with these pumps? I read something on one of the pressure washer pump sites saying OEM pumps on cheaper units only last 30-50 hours and engines 300 hours. I question this. The ebay pump seller says his pump should last 150 hours and that the biggest reason for pump failure is the way they are stored or not triggering withing 2 minutes of trigger release, or running with no water pressure. I sure hate to throw away a good pump though. The guy that gave it to me said this one had more pressure than his new higher pressure unit. Thanks, Jerry
  • 553 Answers
My personal experience is that 40% of all the sellers I dealt with on e*** exaggerated their products or worse. If you decide to go the e*** way be sure you put it on a good credit card so you can get your money back if it's a bust. Don't use your bank card, they're unlikely to retrieve your money for you.
The reason your parts are no longer available is that CH is having their products made in Ch**a now a days.
Here are a couple of sites where you might find your parts;
http://www.ppe-pressure-washer-parts.com/
http://www.industrialpartfinder.com/index.php?main_page=index&cPath=123&gclid=CIWC9teE-6ICFUcz5wod_BYg1Q
If I missed anything just add a comment and I get back to you as soon as I get the message.
Posted on Jul 20, 2010
I HAVE AVANGUARD 9HP PRESSURE WASHER NEED TO KNOW PSI @GPM OF THIS
most rarely exceed 2600 psi as these can blow right through your hand..gpm maybe 40-45..there should be a plate with all that on the unit..
Jul 10, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
2700 psi pressure washer oil capacity in pump
is there a nut with like a glass insert in it thats your oil leavel
Jul 13, 2011 | Karcher FactoryReconditioned 2000 PSI 20...
My GDX 2525 will not pressurize water. I have tried adjusting the calibration knob on to without success.
It could be that the linkage between the engine and pump is broken. Try the key on the drive shaft. This is a piece of metal that locks the pump shaft and the engine shaft. If it still pumps water the problem probably lies elsewhere.
Jun 08, 2011 | Comet Pump Pressure Washer Pump 2.5 Gpm,...
Got a Dewalt 3800 PSI Pressure Washer with 4.0 GPM with a Honda GX 390 gas engine. Tipped it up to roll it out to my truck and got a big puddle of water with what looked like Pump oil in the puddle. Can...
Could very well be. Did you check the oil level and condition of oil? If its too full or if its light brown milky, then water has entered crankcase. Pressure washer pumps cannot stand to ever let run dry. Even a little. Also excessive idling will overheat pump if it doesn't have a thermostatic relief valve that allows some more cool water to enter pump.If it doesn't have one add one. Find your PUMP mfg and model number. IF it's pumping good now and no leaks, quick replacing the seals will save big future repairs. www.pressure-washer-parts.com has lots of info on many pump manufactures. Or get some seals from dewalt.
Aug 11, 2010 | Dewalt 3800 PSI Pressure Washer
Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | Briggs & Stratton Garden
Motor seems to be locked up!!!!!!!!
It may be your engine, but it may also be the water pressure. Try this: Hold the trigger down while pulling the recoil starter. This acts as an unloader for the pressure washer, and may allow the engine to turn over. There is also an oil level in the pump as well as the engine. Check both levels.
Just a thought, but I've been there. Best regards, W/D
Aug 16, 2009 | Devilbliss DeVILBISS Devap DVH2600...
Oil leak under the engine
If it is a vertical shaft engine then it is most likely the crankshaft seal. That requires removing the engine from the frame and removing the pump from the motor to replace the seal. If it is a horizontal shaft engine then it could be either the shaft seal or the side cover gasket. Both require removal of the pump.
Apr 29, 2009 | Garden
Pump doesn't work
ITS ON A KEY WAY JUST PRY THE PUMP OFF
Apr 22, 2009 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Garden Logo
120 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
