Question about Philips Magnavox 9P6034C 60" Rear Projection Television
60in rptv magnavox
Redish tinge on screen not enough blue
    Genius:
  • 1,139 Answers
Hello Butchhugh,
This bight be due to the blue gun failing. What I would do in this situation is to use a CRT analyzer to look a the condition on the CRTs. If it proves to be one of the CRTs, I have some bad news for you. these CRTs are usually a matched set and if you replace one you should replace all three, However there have been some folks who only replaced one CRT only to have to replace the others at a later time. First check the CRTs with a CRT analyzer. Then if the results are good try to measure the voltages on the pins of the CRTs with a voltmeter, you will need a schematic to tell you what these voltages should be. By using the schematic and a voltmeter you should be able to trace down the defective circuit. Now, if you do not have a background in electronics, what I would suggest is that you take your TV to a TV repair shop and have them work on it.
I hope this helps
Thank you,
Shuttle83
Posted on Apr 29, 2008
Color is redish
You have a clogged color print head and needs cleaning or replacement if the old ink hasn't hardened in the jets of the print head.Your printer needs service.
Apr 20, 2010 | Canon Pixma MP950 All-In-One InkJet...
Which way does the first screen on the inside go rough side or smooth side toword projection lamps mom screwed all the screens up waiting for the fluid she moved them around so i don't know which way any...
The sceen with the ridges goes on the outside with the ridges running up and down, on the outside. The totally smooth screen goes on the inside. I hope this helps. Thanks for using fixya.
Dec 14, 2009 | Cars & Trucks
Colours are blurred and very red
Yes, the cooling fluid in the blue and green picture tube assemblies has become contaminated. Thats why the red is predominating. The contaminated growth cannot grow in red light and that is why the red is not affected. The only solution is to have the blue and green tubes pulled and disassembled and cleaned and new fluid installed. This is not a simple job. Most reputable shops charge around $300 to $500 for this repair.
Jul 10, 2009 | Philips 6P4830W 48" Rear Projection...
Philips Magnavox 55P8288A Green tinge over entire picture
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 09, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
TV wont come on anymore
Common problem. Check the site www.tvrepairkits.com. They should have a kit to fix it.
Oct 05, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox model RM8570 A 102 60in rear projection screen
You may want to look at the repair kits on www.magnavoxhelp.com.
They may have a kit for your chasis/model.
Jul 27, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
