Question about White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
MY White rofers 1f78 is stuck
MY White rodgers 1f78 is stuck will not move. the indicators works but does not change. Can it be reset. took bateries and fuse out no change
  • 99 Answers
Reset operation the system must be at cool position then press UP, DOWN and TIME buttons simultaneously. If the reset did not work call the hometechline 18002842925.
Link: MANUAL
Posted on Jul 20, 2010
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
My White Rodgers 1F78 programmable thermostat shows a constant room temperature of 83-84 in the afternoon, but I set it at 77 throughout the whole day and night. Should I get a new one?
It sounds like the temp sensor is defective in the T-stat. I would replace it, get the newer programmable ones, they are very reliable and very cheap to buy online.
Sep 21, 2016 | WHITE-RODGERS DIV 1F78-151 White 70 Series...
My 1f78-151 is stuck! the up and down won't move and it says the house is at 69 but really is at 52
Mary, are you sure the thermostat is in fact getting the furnace to start...???? It sounds like the furnace is NOT starting in heat mode.
Nov 29, 2015 | Sears Parts Direct White-Rodgers 1F78-151...
The white-rodgers 1f78-144 does not work properly
Is it in the heat or cooling mode? Might try a new set of batteries.
Jan 22, 2014 | WHITE-RODGERS DIV 1f78-144 Digital...
I have a White Rodgers thermostat series 1F78-151 that is displaying we at the top?
Hi. This is Aaron Moratalla from White Rodgers. For 1F78-151, "WE" means Wednesday. If left side temperature is stuck at 67F and there's no Hot air coming out then try ressting your thermostat by:
1. set system to Heat mode
2. press simultaneously the Up, Down arrows and Time button for 2sec.
3. the screen should blank out momentarily then show 62F in the right side.
4. set a higher temperature in the right side than the left side of LCD to have a call for heat.
If you are still having problems please don't hesitate to call our Tech Support line at 800-284-2925. Thank you for choosing White Rodgers!
Jan 24, 2013 | White Rodgers White-Rodgers 1F85RF-275...
How to wire white rodgers thermostat 1f78
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from White- Rodger's. First thing you need to do is to verify the function of each of the wires then cross that over to the terminal function of our thermostat. If have difficulty doing this contact us directly at 18002842925.
Jul 30, 2012 | White Rodgers Home Security
My White-Rogers 1F78 thermostat is stuck. There is the number 13 at left and 22 on right and no matter what I do, nothing moves. I put 2 new batteries in and no change. We use it for a hot water oil...
Take off the thermostat face and remove the batteries. Check to see if the back of the thermostat has a capacitor (looks like a small cylinder with 2 soldier connections) short out the capacitor with a paper clip or screw driver then reassemble. This will erase any old memory gliches & you should be able to use it as normal functions.
Sep 12, 2011 | White Rodgers White-Rodgers 1F85RF-275...
1F78 thermostat change from F to C
yes to cut the wire named W904 at the middle.
Sep 19, 2009 | White Rodgers White-Rodgers 1F85RF-275...
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
3,801 people viewed this question
Top White Rodgers Home Security Experts
Nicholas Bannister
Tom Chichester
Heatmeister99
Level 1 Expert
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
