Question about Thetford Porta Potti
I need to change the blade valve seal. How is the easiest way to do this.
Keystone avalanche 290rl grey water tank valve handle replacement
If it's a sliding blade type valve, the handle screws on the threaded rod. Parts are available online or at an RV parts store. The whole valve, with new seals, isn't that hard to change out, just four screws hold the valve parts together.
Sep 08, 2017 | RVs
Tip
All Ford 5.0l engines
A lot of people don't know this. On some Ford 5.0l engine there is a little filter below the positive ventilation crankcase (PVC) valve. Too many people have replaced only the PVC valve thinking the reason for oil blowing out of the valve covers, and any other gaskets or seals, will correct the problem. In reason, the PVC is one of the main areas to check and is the easiest and cheapest way to go. In all, the PVC filter is to blame. Remember preventive maintenance goes a long way have your oil changed regularly.Lee Davidian
on Jan 09, 2010 | Ford Crown Victoria Cars & Trucks
Hydraulic won't lift blade.
sounds like you have a fluid leak, check seals/rubbers and replace if necessary. Might be that you need to replace fluid or top it up with appropriate / similar type
May 25, 2015 | Cars & Trucks
How to change tyre valve stem core
Sometimes you can start turning them out (they unscrew) with a tiny flat blade screwdriver. Or you can go to a parts store and buy a small package of tire valve caps that have the two small prongs for removing valve cores. Walmart probably has them, too.
Jul 06, 2012 | Cars & Trucks
Paslode 350s .The drive pin will not retract behind the next nail. I replaced all the orings and reassembled the way the pieces were (because of minor wear) With the air at 80 to 100 psi it should be...
Usually there are four things that affect the driver not reaching the top of cylinder. Piston oring too tight or too loose, exhaust air is restricted at top of gun , check valve oring is missing, or air leaking down thru blade seal. Assuming that the piston oring is ok and exhaust is not restricted, make sure that oring # 092235 is in place covering the small holes on the outer lower portion of the cylinder. this is the check valve that causes piston to come up. If, however, too much air leaks down past the blade seal, the driver will not make it to the top. Blade seal is a metal washer with slit just large enough to pass the driver blade. If worn, just make a washer out of tire tube and make a small cut with sharp blade just large enough to pass the driver blade. Make the washer larger than the metal washer and just place it on top of the metal washer. Put back together and nail away. Good luck
Jun 01, 2017 | Air Tools & Compressors
Oil is getting into a couple of spark plugs tubes. What is the proper way to seal these tubes?
You have to replace the valve cover gasket and seals. The cover has to be removed to access the seals. Not a hard job. Gasket set w/ seals around $25.00
Jul 31, 2011 | 1996 Dodge Intrepid
How do I get my lawn mower ready for spring time use?
This is what a "General service" looks like at www.arcolawn.com
  • (Mower 2 cycle GS)
GENERAL SERVICE:
1. SHARPENED & BALANCED BLADE
2. REMOVED BLOWER HOUSING & CLEANED COOLING FINS
3. REPLACED SPARK PLUG
4. FLUSHED FUEL SYSTEM
5. CLEANED CARBURETOR HOUSING
6. LUBED CABLES
7. CHECKED OIL SEALS
8. SERVICED AIR FILTER
9. CLEANED EXHAUST PORTS
10. TESTRAN & ADJUSTED.
  • (Mower 4 cycle gs)
GENERAL SERVICE 1. SHARPENED & BALANCED BLADE 2. REMOVED BLOWER HOUSING & CLEANED COOLING FINS 3. REPLACED SPARK PLUG 4. CHANGED OIL 5. FLUSHED FUEL SYSTEM 6. CLEANED CARBURETOR 7. LUBED CABLES 8. CHECKED OIL SEALS 9. SERVICED AIR FILTER 10. TEST RAN & ADJUSTED.
  • (rider tuneup)
Tune up
1.TIGHTENED ENGINE MOUNTING BOLTS
2. INSPECTED BOTTOMOIL SEAL.
3.TEST GOVERNOR OPERATION & ADJUSTEDRPM'S.
4.CHECK SHAFT BEARING.
5.REMOVED BLOWER HOUSING &CLEANED COOLING SYSTEM.
6. REPLACED SPARK PLUG
7.CHANGED OIL.
8.REPLACED OR CLEANED AIR FILTER.
9.ADJUST FUEL/AIR MIXTURE & SPEED LIMIT SCREWS.
10.REPLACED FUEL FILTERS AS REQUIRED.
11.CHECK FUELLINES, VALVES, & CLAMPS.
12.INSTALL FRESH FUEL IN GASTANK.
13.SHARPEN BLADE(S) & CLEAN UNDER BLADE COVER.
14.CHECK DECK, EXAMINE BELTS, PULLEYS.
15. EXAMINETRANSMISSION/DIFFERENTIAL FLUID LEVELS,
16.CHECKGREASE FITTINGS, WHEELS, WHEEL BEARINGS, HEIGHTADJUSTER.
17. CHECK CABLES & CONTROLS ADJUST BRAKE &CLUTCH.
18. CHARGE & TEST BATTERY. (IF EQUIPPED).
19. TESTSAFETY SYSTEMS.
20.REMOVED CYLINDER HEAD & CHECKEDCYLINDER FOR WEAR/DAMAGE. CHECKED ROD BEARINGPLAY. 21.CHECKED VALVES FOR PITTING, WARPING, CARBONBUILDUP & SEATING.
22.CHECKED VALVE STEM CLEARANCESFOR EXCESSIVE WEAR.
23.CLEANED CARBON BUILDUP FROMCOMBUSTION CHAMBER.
24.MACHINED HEAD FLAT.
25.CHECKEDTIMING KEY FOR DAMAGE.
26.CLEANED OR REPLACED POINTSAND CONDENSER (AS NEEDED).
27. SET TIMING. ADJUSTEDMAGNETO AIR GAP.
28.CHECKED THROTTLE SHAFT FOREXCESSIVE WEAR & REPLACED IF NEEDED.
29.DISASSEMBLED& CLEANED CARBURETOR. REPLACED DIAPHRAGM, NEEDLE &SEAT, NEEDLE VALVES ETC. AS NEEDED.(see carburetor section)
I hope this helps! get parts for the service at a dealer like www.arcolawn.com
Feb 14, 2011 | Garden
Oil in spark plug well 02 nissan maxima what could cause this
On the DOHC: The Spark Plug Tube Seals (Washers) on the Valve Cover has developed a leak.
Install new seals.
Remove the Valve Cover to Install the Seals.
If the Valve Cover Gasket have not been replaced recently, go ahead and replace them as well, making sure you clean thoroughly BOTH surfaces before installing any new Seal Washers and Gasket.
Let me me know if this helped, or if you have additional information or questions. Feel Free to contact me on FixYa.com!
ps...I'm replacing (for free!) the Valve Cover Gaskets today on a 1994 Nissan Maxima. Looks like we both will have fun!
If you need the Valve Cover Torque Sequence / Specs let me know on the Comment Section of this Post.
Apr 12, 2010 | 2002 Nissan Maxima
How to remove valve cover gasket on a 1998 honda accord
try removing the bolts hold on the valve cover and once you do that take a razor blade and a little lube and careful scrape the old one off.
Mar 22, 2009 | 1998 Honda Accord
Leaking fron the blade assembly
HELLO
there are two possible solutions
1 change seal or 2 change seal and blades in order to improve the life or your blender.
bye
j roman.
Mar 07, 2009 | VillaWare 5785 Smoothee Bar Work Top...
Thetford Porta Potti  Logo
70 people viewed this question
Top Thetford Camping, Backpacking & Hiking Experts
Patricia Cross
Level 1 Expert
stynger007
Level 1 Expert
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
