Question about Refrigerators
We have a Whirlpool Gold side-by-side refrigerator. The freezer must have started defrosting today. Everything inside is soaked, the ice maker quit producing ice and the ice was melting. The blower fan is running continuously but not blowing any cold air. We did have the freezer packed pretty full but not much more than usual. It seems like the refrigerator is now starting to warm up. We have turned off the freezer side to see if it makes any difference. What else should we do?
    Genius:
  • 1,073 Answers
Call a repair man i think that you have a compressor issue that need attention NOW
Posted on Apr 22, 2008
Whirlpool Gold side by side frigerator freezer ice and water not working, inside frigerator various places freeze, on certain shelves units only 5 years old
As far as the icing up sounds like your cross over have ice. Unplug and defrost even on frost free. Should solve both problems
mike
Dec 19, 2017 | Whirlpool Refrigerators
Ice maker quit working and is causing ice build up on the back of the freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker is frooze up and has quit making ice water has gathered in the bottom of the fridge
this may be a defrost problem being that water in bottom of freezer is coming from frem defrost and drain is blocked
is the freezer down to -18 deg c ?
the other problem is that the water inlet valve is leaking water into chamber when is not meant to
so if water valve is faulty this can happen so replace valve
Nov 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I hear dripping from the freezer section
defrost element is on may need defrost timer
Oct 08, 2009 | Whirlpool GC5SHEXNS Side by Side...
Defrosts/refreezes
IF YOU TAKE THE BACK PANEL OFF INSIDE THE FREEZER YOU WILL FIND A PIECE OF METAL UNDER THE EVAPORATOR COILS IN MIDDLE OF THIS METAL PAN IS A HOLE THAT LEADS THE WATER TO THE BOTTOM OF THE REF FOR EVAPORATION THE HOLE IN THE PAN IS PROBABLY PLUGGED TAKE THE ICE OUT AND CLEAR THER HOLE
Aug 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Sideby side whirlpool- 3 years old- ice maker stopped working 3 weeks ago. today everything in freezer is melting
Verify condenser fan is running. Check evaporator coils for frost. IM will quit if freezer does not go below 5 degrees. The cooling was slowly dieing and finally warmed enough to defrost the food.
Eric
Jul 16, 2009 | Refrigerators
Water buildup in the fridge, dripping in from the freezer
This could be a bad thermostat. If your thermostat never closes it's swith then the defrost element never comes on and you get the problem you are having. Easy fix. Do you know where your timer is and can you retate it?
Jul 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker freezing up
its a confirm defrost timer problem.the defrost timer is a device which after every interval of 8 hours defrosts the freezer part if the timer is faulty it wont defrost and go on over freezing.you can buy the defrost timer for aprox 30 dollars from link below:http://www.repairclinic.com/thanks and plse do not forget to rate the solution.
Jun 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
Jun 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer defrosting
you have a defrosting issue for sure, you neeed to unthaw the freezer coil first and then find out if the defrost heater the defrost timer or the defrost bimetal is the issue one of these three parts is bad
Apr 22, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
