Question about Electrolux Centralux Vacuum
Filtter change (model no. e130f) filtter is falling down some thing is missing to hold it
Bissell model 7920 brush roller is falling down and i am unable to push on the carpet. Can i fix this? How?
You must determine why it's falling Down, it could be a problem with the bottom plate or the nozzle housing where the brush roll should be held securely. The brush roll is held in place by pivot arms that allow it to move up and down. Inspect the pivot arms as that is a likely area that could be damaged.
Feb 28, 2017 | Bissell Vacuums
How do I change the belt on the Soft and Light Hoover Model #U4266930 Hoover send the manual through email, but apparent it is gone now...missing on my favorites list . Attempted to request second...
I have same problem, somehow take top all apart, looks like allen screws holding bag container on, remove that, get to screws right underneath top shell, then get to motor pulley from above . be careful not to pull off motor pulley when wrapping other end of belt around brush underneath, or else you'd have to take top all apart again. Good luck.
Jun 13, 2011 | Hoover Soft Light Supreme U4262-930 Bagged...
Dyson Slim - suction is fine on bottom, but pipe has no suction at all. No blockage. When I remove pipe from the back at the bottom, I can see round white plastic thing in the opening. Right before it...
There is a diverter valve on those that changes suction from the hose to the floor when you pull the handle back. It usually makes the machine bind and not stand up. ( exactly what you are describing ) You need to take it to your local vac shop and they can fix it for you. The part that fell out was the retaining disc and a screw went in it to hold the diverter valve spring in place. Doubful if you can repair this on your own. It will not make since how it should go back if you've never seen it before.
Jun 10, 2017 | Dyson Slim DC18 All Floors HEPA Bagless...
My Mom has a Dirt Devil Featherlite and the belt falls off all the time. I put it on three times today and it falls off within a few minutes. The belt post I put it on doesn't have anything to hold the...
It sounds like the belt is too worn and loose to stay on. Buy a new belt specified for that model of vacuum and install. Ensure that there is only a slight amount of give in the belt when you press the middle.
Jan 05, 2011 | Dirt Devil CE6100 Featherlite Upright...
Just got spinscrub this afternoon and worked great until had to empty dirty water. Now there is no suction at all. Have tried to find clogs and nothing to be found. Am about to return the damn thing!!!
ok 3 things to check before re-boxing it up.
1) make sure that the lid is on properly. it should go on with the 2 tabs at the front of the machine, then click into place at the back of the machine.
2) when you emptied it, sometimes the dirt channel will fall out. This allows for the suction to go between the dirty tank and the clear channel for the water to be sucked back up.
3) when you remove the dirty water tank again, look down inside the machine for a circular hole. there should be a rubber gasket on it to seal up the tank for your suction. If it has come loose or is missing, retrace your steps between the machine where it was last used and the sink or wherever you dumped out the dirty water.
Good luck,
Mark
Nov 11, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Where does the hepa filter go
Look for a removeable grille at the top or back of the vac shaped similar to the filtter. The filter is an after filter so it sits beyond the bag
Sep 10, 2009 | Bosch BSG71310UC Bagged Canister Vacuum
Hoover Z 700 Model U9145-900
Try going to hoover.com and either email them or there is a number that you can call, this is hoover direct, so someone there should be able to help you. Have your model and serial numbers and purchase date handy in case they ask. It also has a 2 year warranty on it. So if you bought it in the fall of 2006, then you have until the fall of 2008. I would take it to an warranty servicer and get it repaired before the warranty runs out.
Mar 18, 2008 | Vacuums
Hoover self-propelled windtunnel belt pops off
The correct belt is a 38528035. If the belt does not have this number printed on it, it is a generic belt and probably the wrong one. The pulley on the transmission is "convex" because this pulley design keeps the belt running in the middle. (a belt will always try to "climb up a hill") If the motor shaft and the pulley are not aligned properly, the belt will constantly throw off. This can be a result of a bad motor mount (located inside the motor compartment.) The motor shaft end has a rubber cover that absorbs vibration and keeps the motor positioned squarely. The handle could also be loose on the pivot. It is held down by two metal clamps that screw securely to the bottom, holding the handle on to the base and allowing for the handle to pivot backwards. This problem can be difficult to diagnose and I have had many in my shop for repair. It takes a seasoned and experienced repairman to find a solution to this problem, in most cases. The disadvantage I have here is that I cannot see your machines to inspect all the various things that effect the belt alignment. I hope that some of this information will help.
Oct 15, 2007 | Hoover U6630-900 WindTunnel Bagless...
Electrolux Centralux Vacuum Logo
89 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
