Question about Mitsubishi CS-40707 40" TV
What's the best procedure for removing the back case from my Mitsubishi 40'' tv 40503?
  • Bob Appleton
    Bob Appleton Jul 20, 2010
    The solution was just what I needed. I was looking for confirmation of what I was doing and I got it.I like your website and will return whenever I need similar help.
    Bob Appleton
  • 4,889 Answers
The back cover removal should be a straight forward procedure. Just remove the screws and pull it out. Its the chassis thats the tough part especially if you want to slide it out. A service manual should have detailed dis-assembly instructions.
Posted on Jul 20, 2010
  • 4 more comments
  • eagle338
    eagle338 Jul 20, 2010
  • Bob Appleton
    The cabinet came off, no problem. Thanks. Is there a fuse on this model that would cause the whole set to go dead all at once? If so, where is it located? 40" CRT Mits model 40503
  • eagle338
    This fuse you are talking about can cause the set to go dead, although there are hell lot of other things that can cause it. Its a 6A-10A glass type fuse located right next to where the power cord goes into the board.
  • Bob Appleton
    Found the fuse. Got it out. Checked it out. It's good. Not willing to throw money at it so will start researching a new flat screen. Any suggestions?
  • eagle338
    Flat screen LCD? If yes then LG's range of LED backlit LCDS will be good. More contrast ratio, more life(LED backlights last longer than CFL backlights) and less power consumption.
  • eagle338
    eagle338 Jul 21, 2010
    Thank you for using Fixya!
Remove parental lock on a mitsubishi CS-40503
model# cs-40503 default parental code is 6629
Nov 16, 2009 | Mitsubishi CS-40503 TV
The TV LEVEL SOUND OPTION IS NOT WORKING - MODEL CS-40503
I feel your pain. I understand there is legislation pending that will force the broadcasters to stop that ****. In case you have been misinformed that is NOT a problem with your tv. It's an issue with the broadcaster.
Jun 16, 2009 | Mitsubishi CS-40503 TV
We have a 40" Mitsubishi tv and we have Seniors that would like close caption but I cannot get it on, how do I fix it?
check the remote if there is a function for closed caption.but sometimes,the movies don't have one. or its not compatible with the closed captions.
Apr 06, 2009 | Mitsubishi CS-40503 TV
Just bought a mitsubishi 40503 dont have manual cant get my cable hooked up
check if the plug if your cable is fit for the antenna in of your tv.if ok then hook it up and do the manual/auto search of channels.
Mar 28, 2009 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 shuts off while watching.
Could be any number of things, none of them easy to diagnose. Unless your a TV repairman it's probably not worth fixing. It will cost tou more in repairs than a new TV.
Sep 28, 2008 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 Horizontal Picture Problems
Your trouble is with the vertical deflection circuitry. You'll need to have it serviced by a professional.
Sep 13, 2008 | Mitsubishi CS-40503 TV
FORGOT PASSCODE ON TV PARENTAL LOCKOUT
that's a big problem. sometimes using the 0000 can unlock it but it's not 100 percent.try the trial and error.
Apr 19, 2008 | Mitsubishi CS-40503 TV
1995 Mitsubishi 40" Television - Worth Repairing?
there are bad solder connections on the vertical deflection IC resolder them and you will be fine
Mar 13, 2008 | Mitsubishi CS-40503 TV
Weight
I have one of these TVs and still love it.  The manual says that the weight is listed at 250lbs (approx.).  Most of the TV stands in retail stores only hold up to 240lbs., so that is something to consider.
Sep 23, 2007 | Mitsubishi CS-40503 TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
