Question about LG LSC26905TT Side by Side Refrigerator
Can't get ice or water from the door
I smelled something burning. after that the lock light and the light at the dispenser does not come on, the other indicator lights work. but can't get water or ice from the door. model # lsc26905sw
I smelled something burning. after that the light at the dispenser does not come on, the other indicator lights work. but can't get water or ice from the door & solenoid got just 36v instead 120
model # lsc26905tt
Posted on Jul 23, 2010
Have a Kenmore Coldspot Model 106.56713500. Ice maker works fine, but the dispenser makes a sound for 1-2 seconds then stops and won't dispense or make any more sounds. Smelled something burning.
This unit has a motorized doorway for the icemaker so you are most likely hearing the door opening up. If you remove the ice bucket and put a piece of tape on the light switch you can have the door open and see what is happening.
Reach your arm around and hit the ice lever while looking down the chute and the door should open (about 2 seconds from the time you push the ice dispenser button) and right after it is open then the dispenser control board will start turning the auger.
Smelling something burning is never good!! And unfortunately, the board is usually what cooks on these part# WP2252174 @ 193.26 from sears. Sometimes the motor itself shorts and takes the board with it and that part# WP2252130 @ 122.52 from sears although in all of the auger motors I've changed, none have smelled like it burned but probably 90% of the control boards have.
Can it be fixed? I'm sure but the parts alone can hit 400$ so you have to ask if it is worth it? If it still makes ice then just reach inside, save 400 and put it in a drawer for a new fridge when that one breaks.
Feb 02, 2018 | Kenmore Refrigerators
The ice and water dispenser of the door is locked on after hummin
Mark check for a door switch on the cabinet side oft the freezer door. It usually is near the hinge fold area of the door. Depressing the plunger should make the freezer compartment light go on and off. The switch also controls the icemaker auger power by shutting it off when the door is open. If the door switch has failed you will not get ice or water from the door dispenser. There are 2 plastic lock tabs of the side of the door switch to remove it. Use a knife blade or putty knife to unlock the tabs on the switch. If you need more help as to location of the switch respond here and I will pass a link for the diagram.
Jun 05, 2010 | Maytag MSD2756G Side by Side Refrigerator
Trying to reset filer light after changing filter-locked up
Here is a link to the manual for your unit. Copy paste into your browser.
http://shop.amana.com/assets/pdfs/literature/12591321.PDF
Page 20 shows how to unlock the dispenser and reset the filter light and I have pasted them here.
There are products at Lowes or Home Depot near the appliance for odor removal, I like to put a bowl of cotton balls on a couple of shelves, soak the cotton in vanilla once a day. The odors will be gone in a couple of days.
DISPENSER LOCK
(SELECT MODELS)
This feature prevents ice or water from
being dispensed.
To lock dispenser:
➢ Press and hold DISPENSER LOCK
button for 3 seconds. A green
indicator light above button confirms
dispenser is locked.
To unlock dispenser:
➢ Hold DISPENSER LOCK button for 3
seconds. Green indicator light above
button will go out.
Filter reset
The filter status indicator light
serves as a reminder to replace the
water filter. A green light indicates that
the filter is in good condition. A red light
indicates the filter should be changed.
Once light turns red, it will remain red
until function is reset.
To reset indicator:
➢ Press and hold both DISPENSER
LOCK and WATER buttons
simultaneously for 4 seconds. The
green filter status indicator light will
flash 3 times when the function has
successfully reset.
Apr 18, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Water would not stop running into icemaker, now
The water inlet valve(where the water supply connects to the back) may have been staying open and now has burned so it don't work at all. . You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it.
Mar 25, 2010 | Refrigerators
There is a smell from outside the frige
check drip pan for smell see if ice maker lever switch is up for noise
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Plastic burning smell coming from bottom front vents.
u may need to unplug it then tip it enough to see under it to see if maybe a mouse chewed on some wires and try to rewire or electic tape on some bare wires
Mar 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
340 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
