Question about AT&T High Speed DSL Modem
User name and password
Want to access the wireless interface directly to change the network name and password via 192.168.1.1. What is the default username and password?
  • 62 Answers
Try with these login credentials
username: admin
password: admin
(or)
username: admin
password: password
Posted on Jul 22, 2010
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
Cause:
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
.how can i find out what my security key is on my
To view the wireless security key info, you'll need to access the router's set up page. If you left it at the default address - that will be 192.168.0.1. You would enter that number and decimal points into the address box of your browser. I'm assuming that you have access via wireless signal - and simply need to know what the info is for use on another device. If you are not able to connect wirelessly, you'll need to use a computer that is connected by a network cable to the same network.
After accessing the setup page at 192.168.0.1 (or the page you changed it to from the default), you'll be prompted to log in by supplying user name and password credentials. Again, if you haven't changed from the default settings, enter "admin" (no quotes) for the user name and "password" (no quotes) for the password boxes.
If you are not able to get to the set up page because you changed it or you're unable to recall the login credentials, you will have to perform a master reset on the router. More on this, later.
Once logged in, click the Wireless link in the main menu of the browser interface. The Wireless Settings menu will appear. At the bottom of the page, the wireless security options and keys are presented.
A master reset is a last resort to access the settings of the router. If you do not know the IP address or user name and password info, this will be the only way back into the set up options of the router. A master reset will erase all custom settings and replace them with default values - like when it left the factory. This is done by pressing the recessed reset button on the back of the router - between the WAN and LAN ports. Press and hold the Reset button until the Test LED turns on (approx 10 seconds). The router will then reboot with the default operating settings.
You can download the manual for free, here.
Please take a moment to rate this reply - thanks!
Dec 02, 2010 | NetGear DG834G Wireless Router
I want to change password for wifi network
Open up an Internet browser window on your computer system. To gain access to the default settings, type in the default IP address of the wireless router in your Internet browser's address bar and press enter. You must refer to the wireless router's documentation or navigate to the manufacturer's website for the correct IP address.
Type the default user name and password in the security dialog box that appears, then press Enter on your keyboard. Because different router manufacturers use different default user names and passwords, refer back to your router's documentation or support webpage for the correct information.
Navigate through the router administration pages to find the wireless router's administrator password settings. Change the default user name and password to a unique set so that possible unauthorized access to your router settings will not take place. Make sure to hit "Save Settings" to complete the change.
Set up your wireless security settings by navigating to the proper administration settings page. By default, wireless routers do not come with a password for connectivity access. Choose the appropriate wireless security level you need and type in a unique user name and password. Save these new settings and log out of the router's administration setup.
5
Write down the user names and passwords for both network access and the administration setup page. Keep these user names and passwords in a safe place.
Thanks.
Have a great day.
Oct 14, 2010 | Computers & Internet
How to open asus wifi router home page?
In order to access the web interface of the router you should know the IP address of the router. Please try the following steps to check the ip address on the computer which is connected with the router (wired/wireless doesn’t matter).
1. Click on start the go to run and try cmd and click on ok.
2. Type ipconfig and press enter.
3. look for the default gateway numbers.
the default gateway is the address of the router. Open internet explorer and type http://default gateway numbers (for example http://192.168.1.1)
It should take you to the web interface of the router on which authentication is needed. The default user name and password is admin and admin.
Let me know if it help.
Rashish
Aug 09, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
How to secure my internet connection via smc router
If you plan to have a wireless network, you should set it up so that only people you choose can access it. Here are a few options for wireless network security.
Wired Equivalent Privacy (WEP)
WEP is a widely used network security method. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. The receiving computer needs the key to decode the information so that it's difficult for someone on another computer to get onto your network and access files without your permission.
Wi-Fi Protected Access (WPA)
WPA was created to improve the security of WEP. Like WEP, WPA encrypts information, but it also checks to make sure that the network security key has not been modified. WPA also authenticates users to help ensure that only authorized people can access the network. If your networking hardware works with both WEP and WPA security, we recommend that you use WPA.
There are two types of WPA authentication: WPA and WPA2. WPA is designed to work with all wireless network adapters, but it might not work with older routers or access points. WPA2 is more secure than WPA, but it will not work with some older network adapters. WPA is designed to be used with an 802.1X authentication server, which distributes different keys to each user. This is referred to as WPA-Enterprise or WPA2-Enterprise. It can also be used in a pre-shared key (PSK) mode, where every user is given the same passphrase. This is referred to as WPA-Personal or WPA2-Personal.
802.1X authentication can help enhance security for 802.11 wireless networks and wired Ethernet networks. 802.1X uses an authentication server to validate users and provide network access. On wireless networks, 802.1X can work with Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) keys. This type of authentication is typically used when connecting to a workplace network.
IF THIS ALL DOSEN'T WORK TRY THE FOLLOWING:
Wireless network security recommendations
If you have a wireless network, there are some additional security precautions that you should take.
Use a network security key
If you have a wireless network, you should set up a network security key, which turns on encryption. With encryption, people can't connect to your network without the security key. Also, any information that is sent across your network is encrypted so that only computers that have the key to decrypt the information can read it. This can help avert attempts to access your network and files without your permission. Common wireless network encryption methods are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA) and WPA-2.
Change the default administrator name and password on your router or access point
If you have a router or access point, you probably used a default name and password to set up the equipment. Most manufacturers use the same default name and password for all of their equipment, which someone could use to access your router or access point without you knowing it. To avoid that risk, change the default administrator user name and password for your router. Check the information that came with your device for instructions about how to change the name and password.
Change the default SSID
Routers and access points use a wireless network name called a service set identifier (SSID). Most manufacturers use the same SSID for all of their routers and access points. We recommend that you change the default SSID to keep your wireless network from overlapping with other wireless networks that might be using the default SSID. It makes it easier for you to identify which wireless network is yours, if there is more than one nearby, because the SSID is typically shown in the list of available networks. Check the information that came with your device for instructions about how to change the default SSID.
Position your router or access point carefully
Wireless signals can transmit a few hundred feet, so the signal from your network could be broadcast outside of your home. You can help limit the area that your wireless signal reaches by positioning your router or access point close to the center of your home rather than near an outside wall or window.
Aug 03, 2010 | SMC Barricade 7004VWBR Wireless Router
I don't know how to reinstall the linksys access point!!! Our wireless network that we made simply disappeared, so I'm trying to re-make one. However, when I tried that with a flash drive, it couldn't work...
T
o access the Access Points Setup, and the LAN IP address has not changed, then computer must have an IP address of 192.168.1.XXX. If the Access Point is plugged in via Ethernet to a Linksys Router and the computer is also connected a Linksys router via Ethernet, then the PC should already have a correct IP address (unless the LAN IP Address of the Router has been changed). If unsure, please assign the computer a Static IP Address so it will have an IP address in the same range as the Access Points IP Address.
If the Access Point is being connected to a hub/switch/router via Ethernet, then use the cable that was provided with Access Point. If the Access Point is being connected to the computer directly, then a Cross Over cable must be used. Cross over cables can be purchased at most electronic stores.
    Remember: When ever a change is made in the Setup of the Access Point, the Apply button must be used to save the settings to the Access Point.
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Access Point.
      Default IP addresses:
    • WAP11 v2.8 - 192.168.1.251
    • WAP54G v1.1 - 192.168.1.245
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Access Points password (The default password of a Linksys Access Point is admin) into the "Password" field.
May 14, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
No network code for router want to connect my laptop to it
Hello friend,
i guess that you are talking about wireless code, in this case you will need to connect the laptop to the router via Ethernet cable to configure it and then unplug the cable and use the wireless.
so you connect the ethernet cable between the laptop and one of the ports on the router from 1 to 4. then access to the router web interface which is usually 192.168.1.1. then go the wireless tab and name your wireless access point and put a password to secure your network. After that you can unplug your Ethernet cable and use the wireless on your laptop to connect your router wirelessly.
Best Regards,
Oct 31, 2009 | Linksys Wireless-G Broadband Router
Router working; couldn't add user name, password
A router has usually two different passwords - one to access the router configuration, another one for the wireless security.
the first one is used when you access your router via a web page, mostly http://192.168.1.1 or http://192.168.0.1. The username here can not be changed and varies from router to router ( admin and root are most common.) The password can and should be changed from the default, because otherwise everyone who has access to your network can change and therefore "own" the router.
The second password (also called network key or passphrase) is for the wireless access to the router. (Look for something called WEP-key or WPA.) You can change that after you are logged into your router via web page (usually under a "Wireless Security" tab.
This is how specific I can be without knowing which router you are using, but I think it gives you a general overview. If you would like more details, come back here and leave a post with more details about your router and I'm happy to help.
Apr 15, 2009 | Computers & Internet
How to sercure my wireless network
Securing a wireless network includes:
1. Setting a router admin password so nobody can get into your router (do this by using the default user/password to access the router and in Basic settings set a password...go to http://192.168.1.1 in your browser to access the web interface.
2. Set up a SSID for your network...this can be any name with numbers value...its just a description
3. Set up under wireless settings you WEP encrption with a password so when you scan for wireless networks you will find your SSID named network and when it prompts you you enter the password you set for WEP.
Oct 21, 2008 | NetGear MR814 Wireless Router
How to change router default name and password
you can't change the default name...that is always left blank, but you can change the password.
Access the user interface & click on Administration.  It should automatically be in the Management section at this point.
Enter your desired password in the Router Password field.
Re-enter to confirm the password in the next field.
Click on Save Settings.
For more information on working with your router, you can access the User Guide provided by LinkSys:
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&pagename=Linksys%2FCommon%2FVisitorWrapper&cid=1166859837401&displaypage=download
Oct 27, 2007 | Linksys Wireless-G WRT54G Router
AT&T High Speed DSL Modem Logo
373 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
