Question about Freezers
Hello I have a frigidare upright freezer i want
Hello I have a frigidare upright freezer i want to remove the shelves & adjust the height how do I do that
  • 112 Answers
You can't....most freezers have set position so air can rotate evenly for a reason.
Posted on Jul 20, 2010
How does the Ignis afe550/ig Upright Freezer defrost?
I couldn't find any info on your freezer but there are 2 main ways units defrost. The first is manual defrost where you have to unplug the unit to defrost it yourself. These unit are typically chest freezers and upright freezers that have no fan and the refrigerant runs through the shelves. You can tell because frost will mainly build up on the shelves themselves. The second is self defrost. These units will have a fan in the freezer and a evaporator coil behind a wall inside the freezer. This wall is usually inside the freezer on the back wall. These units have a heater that is activated by a timer and comes on every 8 hours or so and will heat the coil for 20 to 30 minutes. This removes all the frost build up on the coil and you should never have to do anything. I hope this helps.
Feb 22, 2015 | Freezers
What size is a frigidare 297080400 upright freezer
Hello friend, thank you for your post!
In order to provide you accurate information could you provide me with your model number please? Normally you can locate the serial tag (which lists your model number) on the inside wall of your freezer. With that information I can provide you with the cubic ft. of your freezer. I look forward to helping you further. -Matt
Oct 04, 2014 | Frigidaire Freezers
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
How do I reinforce freezer shelves?
The freezer should not be totally be full otherwise the cooling system will not succeed to reach its design temperature. If the shelve is still bending, get a piece of maple about 1x2" and attach it to the shelve at each end with a piece of nylon rope.
May 01, 2014 | General Electric FUF21SVRWW GE 20.6 Cu....
I have a Magic chef upright freezer i can hear the compresser running but it will not freeze meat
Has this happened suddenly? Look at the shelves to see if there is a frost line. If the shelves that also carry the Freon appear to have a frost line your freezer may have a Freon leak. If there is a Freon leak it will be better to begin looking for a replacement freezer. Let me know what you see, Thanks Sea Breeze
Nov 29, 2012 | Magic Chef 11.8 cu. ft. / 334 liter...
FRIGIDARE'S UPRIGHT FREEZER*
Hello - What exactly is your concern? Is the freezer not cooling or displaying an error code?
Oct 11, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
I HAVE AN UPRIGHT FREEZER THAT IS DEVELOPING FROST ON ALL THE SHELVES, I DEFROSTED IT TODAY AND RIGHT AWAY THE SHELVES DEVELOPED FROST AGAIN. THIS HAS NEVER HAPPENED BEFORE, IT WOULD GET FROST ON THE...
Sounds like an air leak. Check the door gasket. If that is sealing well all the way around, try putting a peice of foil duct tape over the two small vents in the bottom of the door.
Sep 05, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Top shelf of frigidare manual defrost freezer only freezing, other shelves are not cooling.
Is the condenser clean? If it is you may have a refrigerant leak or an inefficient compressor.
Jun 28, 2009 | Frigidaire Freezer Refrigeration White...
Freezers Logo
81 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
