Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
LOUD noices When the ice falls into the ice container, it is VERY loud! I can hear it from any room in the house. Is there anything that I can do to make that quieter?
    Problem Solver:
  • 14 Answers
Samsung is made in Mexico. I know if ice is low and dump into the basket it is loud. Samsung is a Korea company so is LG.
Posted on Feb 01, 2016
  • 112 Answers
No....not short of sticking a pillow over the front of the door...Its a Samsung made in Korea.
Posted on Jul 20, 2010
I am hearing a crashing sound in my house periodically. It sounds like ice crashing in the pipes. This only seems to happen at night. Does anyone know what this might be.
if you have an ac running during the day but it could be ice on the evaporator unit melting off and falling into the drip tray as the unit reaches the controlled air temp setting and switches off
Jun 14, 2018 | Refrigerators
What causes the ice maker to be loud
Hey Tony, thank you for you inquiry. I understand that your ice maker is a little louder than expected. Typically you will hear
ice cubes falling into the ice bin. Also, the ice maker fan, water valve activation & refrigerant gas may create sounds during IM operation. Please elaborate prior to your problem, are there any other symptoms before having this issue that I can try to further assist you with? If you can think of anything in particular, please feel free to reconnect. Best regards, JK
Oct 14, 2015 | Frigidaire Refrigerators
Hi, we just purchased an 5 year old GE profile refrigerator with full door/bottom freezer from a private party. It was working fine at his house. The refrigerator has a loud buzzing every 1/2 for a few...
The buzz is most likely coming from the water valve that feeds the ice maker. If the ice maker is not being used the buzz will continue unless the power is disconnected to the valve. It does not hurt anything but can be annoying.
If the ice maker does not have the shut off handle (arm) to lift then a solution would be to unplug the ice maker itself. If you look at the ice maker in the freezer it is usually held on by 3 screws to the side wall. If you remove these screws there will be a wire plug that you can unplug and remove the entire ice maker and free up room. With it disconnected the buzz will stop.
Apr 18, 2010 | GE Profile Stainless Bottom-Freezer...
The motor arm seems extremely loud. Machine is
Run the machine in another room.
It is due to Cuisinart's cheapo motor.
Also try 1/2 to 2/3 fill batches.
Put a book and a medium food can on top of motor arm to keep it from lifting while mixing.
Jan 25, 2010 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
I have had the GE top frezer a little over 2 months...Afew weeks ago I noticed a noise starting , a kind of weird noise....(its not the ice maker....I turned that off a week ago and it still does it....the...
Sounds like the defrost timer doing its job but with loud efforts. GE is known for its different sounds some clanks to clicks to popping. Thank God for good hearing but curse GE for its poor noise reduction efforts. This is why GE is cheaper than its other competitors. They cut corners welcome to the world of GE. BB
Dec 15, 2009 | GE Refrigerators
My Samsung RF266ABRS makes a sound like ice falling into a bucket
Check with the people you bought it from. There should be a warranty.
Jun 26, 2017 | Samsung Refrigerators
Water leaking through ice maker
check out the temperature inside of the freezer your probebl going to have to clean the condenser coiul underneith the unit
May 23, 2009 | Whirlpool ES5FHAXS Side by Side...
Always dispenses CRUSHED ice
try removing the ice bucket, and on the back wall is a hole approx 1.5 inches square that the brass bar attached to the rear of ice container inserts into,(you may have to put hte container back in partilaly to look under and watch where it slides into) inside thatcut-out is a plunger that slides up and down activating the crushed/cubed option.you can sick you finger in the hole you should seee a plastic hoop that would catch the brasss bar.Try pushing and pulling hte hoop up and down if it does not move freely, youll need to replace the solenoid assy. if it does, then pull allthe way to the lowest positon and make sure when replacing the ice container that the bar falls with in the hoop itself
Mar 22, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator is making a loid noise
** the y do sound directly related. water is dripping down your ice maker falling on to bucket? well a small amount of water is also falling onto the evaporator fan assy, freezing and the **ise you hear is that fan blade "cutting" through the ice.you can lift the arm turning the Ice maker to the off position, itll stop calling for water,and your **ise should stop as well
Mar 10, 2008 | Refrigerators
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
152 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
