Question about Sony KP-41T65 41" Rear Projection Television
Tv will not turn on 3 blinks - Sony KP-41T65 41" Rear Projection Television
  • 2 more comments
  • lesleyx Jul 13, 2008
    The TV front panel red light blinks 8 times the screen goes blue and then the tv turns off, yet you can still hear the sound. I have called Sony and they can offer no solutions other then call a repairman, they claim they have not received similar complaints in the past. Sounds hard to believe given the number of complaints I have recently read.
  • lesleyx Jul 14, 2008
    The TV is a Sony Color Rear Video Projector - KP 57hw40 / Mfg. February 2002
  • LADYDY0403 Jan 09, 2009
    KP-41T35
    Red light continuously blinks (timer light)
    No picture, No sound, No power
  • Patti Watkins Jan 21, 2009
    When you turn on the TV, the Red light blinks, but no sound, no picture. Through a telephone conversation the repairman said it might be a capacitor. I'll find out Monday. Estimate $250-$300 in GA.
  • Sony Master
  • 8,617 Answers
Is this a panasonic rear projection TV? let me know the model number and I should be able to help you
Posted on Apr 22, 2008
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Picture went out and no audio, red light on power blinks seven times and repeats.
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Feb 15, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
TV will not turn on. Power light blinks 7 times, then pauses, blinks 7 times again. What could the problem be?
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Jan 11, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
Tv will not turn on. red light on front of tv next to on/off button blinks
COUNT THE BLINKS.
3 BLINKS AND A PAUSE AND 3 BLINKS IS MOST COMMON.
5 BLINKS AND A PAUSE AND 5 BLINKS IS ALSO COMMON.
let me know the error code (blinks) and I will tell you what it means.
SD TECH
Jun 10, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Turn tv on tv nothing happend red light blinks 3
O would need the model number to assist you, as the s blinks is an error code, but error codes are model specific.
Nov 26, 2009 | Televison & Video
Need code for programing
Manual is available at One For All here
http://www.oneforall.com/uploads/support/6c8b036cd3ba3806d00e5a1c57409ef0.pdf
To set up remote
1. Turn on TV.
2. On remote press TV key once.
3. Press and hold Set button until LED blinks twice
4. Enter first 4 digit code for your TV manufacturer from the manual above (P.18). LED blinks twice if code has been entered correctly, if not go to 2.
5. Press Power and the TV should switch off, if the TV doesn't switch off go to step 2 and repeat with next code for your brand until TV does turn off.
Searching for code
1. Perform steps 1 to 3 as above.
2. Enter the code 991. LED will blink twice.
3. Press Power button.
4. If TV turns off
Press Set - LED will blink twice.
If TV doesn't turn off
Press TV button and go to repeat step 3 and 4, until TV does turn off.
Check a code.
If you've used the search function you might want to know what the code is to do this...
1. Perform steps 1 to 3 from set up remote at the top.
2. Enter code 990, LED will blink twice.
3. For the first code press 1. Wait 3 seconds and count the times the LED blinks, that is your first digit, if the LED doesn't blink that is 0.
4. Repeat step 3 for remainder codes, pressing 2 for second digit, 3 for third and 4 for fourth.
It doesn't state in the manual how to get out of this mode but normally it is either leave the remote alone for 5 minutes, or press any other button other than 1 to 4.
Nov 10, 2009 | Televison & Video
Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Rear projection tv turns off after 3 seconds, power indicator blinks 3 times at 5 second intervals.
Most times 3 blinks is the defective lamp code. See your owners manual for instructions on changing the lamp.
Feb 24, 2008 | Televison & Video
Sony KP-41T65 41" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
