Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Leaking Fridge THE PAN AT THE BACK OF FRIDGE IS COLLECTING A LARGE AMOUNT OF WATER.
  • 112 Answers
Its designed that way.....if it is not overflowing its fine....its the auto defrost mode setting doing its job.
Posted on Jul 20, 2010
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
Eaton's Viking Model 1266F fridge leaking defrost water
Your idea/plan sounds pretty good. There is a drip pan under the fridge right? it might be a good idea to run it into that. Good luck!
Jul 26, 2014 | Viking Refrigerators
Admiral model ltf2112ar
Leaking Refrigerators
3caed0f4-b74f-42aa-9c98-c6b216270899.jpgCan you send me a photo of this problem? I think there should be a bowl that should collect the water from defrost and drain the water down to a pan next to the compressor. If you are unable too place the picture here then contact me HERE I am here to help so please respond, Thanks Sea Breeze
Jul 31, 2013 | Refrigerators
I am having a problem with water leaking inside of my fridge. It is coming from the top back of the fridge. I have pan collecting the water and it actually is freezing inside of the pan and turning into a...
You have a clogged auto defrost drain.You will need to locate the drain and clean it out. Without the model number that is about the only info I can tell you. Hope this helped.
Jun 11, 2011 | Refrigerators
Water from freezer compartment collecting at bottom of frig; under veg. drawers.
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water2_bing.gif in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain2_bing.gif wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running2_bing.gif into the drain hole...Please feel free to comment again if you have any other question. Mike
Nov 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
We are getting water build up under the crisper drawers --a large amount
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 25, 2009 | Roper Refrigerators
Leaking water on floor
find where line comes out under fridge in pan and blow back through line with shop air. clean evap pan inside freezer by defrosting and cleaning pan.
Sep 23, 2009 | Refrigerators
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Whirlpook ET21NK--Water collecting in crispers
Self-defrosting refrigerators turn themselves off to defrost once in each 24-hour cycle. There is a 'drip pan' under the refrigerator that catches water from this automatic defrost cycle. The pan is not very deep, so if the unit is leaning very much, water will run over the top of the pan. For this and other reasons, you should try to keep the unit as level as possible.
Aug 21, 2009 | Refrigerators
Water/condesation collecting at the bottom of my fridge
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 09, 2009 | Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
101 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
