Question about SanDisk Sansa m250 MP3 Player
SansaDisk Sansa m250 (2GB) "Finalizing update"
My SansaDisk Sansa m250 (2GB) has problems when syncing music to it. When I plug in the USB into my computer and into my device, it could sync with ease. After I finish syncing, when I turn it on, the player stays on the screen, "Finalizing update" and it would not go anywhere else. I've tried rebooting it 4 times and left it on that screen for 6 hours, someone please help me.
  • 593 Answers
You need to go to the Sandisk support site and down load the Updater program. Run the updater on your player. This in a way reinstalls the software on the player kind of like reinstalling the operating system. [
Posted on Jul 20, 2010
I NEED TO KNOW HOW TO DOWNLOAD TO THE SANSA CLIP MP3
First, connect your SansaDisk to your computer via the USB cable. Secondly, open your Windows Media Player. You can sync the musics from your Windows Media Player to your MP3 player.
Dec 24, 2009 | SanDisk Sansa Clip MP3 Player
When I turn it on, the Refresh database screen comes on but never complete. No matter how many time I reset the unit, it seem to be jammed to that screen. How should I fix the problem?
I've run into this issue before with my SanDisk Sansa the issue is typically either you are running close the to the size limit or there are some large files that have corrupted. I've fixed by completely removing all the files from the device. Please keep in mind the below steps will remove all the music from your device and this will need to be synced back over:
1. Connect the SanDisk to a PC via the USB cable
2. After this is connected it should show up as an additional drive in the My Computer window (possibly E or F, but this varies).
3. Expand the corresponding drive letter until you get to where your music is stored.
4. Delete all the music folders/files
5. Disconnect the SansaDisk from the computer and then power it off and then back on.
The Database should refresh properly and then you should be able to begin syncing items back to the device (I would suggest syncing items in small blocks to prevent any corruption from occurring again). If you encounter any problems, let me know.
Nov 27, 2009 | SanDisk Sansa e270 MP3 Player
Stuck on finalizing update and computer wont recognize.
yet i don´t know much about your mp3 ..
is there any reset "button" if so try that
May 25, 2009 | SanDisk Sansa m250 MP3 Player
Someone gave a sansadisk e260 and I want to know how to clean it(or delete all the music that it came with)so that I could put the music I like. The manual don't explained very much.
Under settings, there is a Format option. Select that option and the disk will be erased of all preloaded stuff. From there, connect it to your Windows machine and either use Media Center to sync your music or open the Sansa up like a drive and drag the music to there.
Mar 19, 2009 | SanDisk Sansa e260 MP3 Player
How do i download music from computer to sansadisk
Well if your using Windows Media Player. I can fix this problem easy. Just go to the sync tab then on the side and add music to the sync list. If your not I can't help u. Oh also if your using itunes it dosent work.
Feb 01, 2009 | SanDisk Sansa e200 MP3 Player
Sansa Clip does not show up on computer
I had the same problem all you've got to do is first turn on the sansa clip.Then go to settings. After that scroll down to USB mode (second from bottom) then it woul probably say auto detect. Scroll down to MSC then hit enter. If that doesn't work try MTP mode.
Jul 11, 2008 | SanDisk Sansa Clip MP3 Player
Sansadisk
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 19, 2008 | SanDisk Sansa Clip MP3 Player
Sansadisk problem
-Tha Mp3 Doctor
Troubles, "finalizing"
Finalizing is normal, unless it gets stuck for over 30 minutes
-Tha Mp3 Doctor
May 16, 2008 | SanDisk Sansa e250 MP3 Player
Finalizing updat
Firmware upgrade needed to solve your problem
-Tha Mp3 Doctor
Apr 25, 2008 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
422 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
