Acer Extensa 4620 Notebook Logo
Posted on Jul 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dvd Windows media can not detect a dvd in drive on my acer laptop!
Anonymous
Level 2:
New Friend:
  • Expert 109 Answers
  • Posted on Jul 20, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
109
Questions
0
Helped
25444
Points
229
Is it just dvd's that windows media can't see or is it audio as well?. one thing you should do is download the driver for the cd drive on the latop from acer and see if there is any differance.
1helpful
Which buttons to press on my acer laptop to start a golf dvd disc is in slot
You will need a program to run DVD's on your computer.
If you have Windows the easiest choice would be Windows Media Player
Navigate to Control Panel and type in "Default" run down the list and select "Windows Media Player"
When I insert a DVD in my Acer I automatically get a menu come up
(Windows 10) giving me options of what I want to do with the DVD including "Play" .......Duh !!
If you need more help give some information on your OS
Earlier OS I used to have to go to Computer and the DVD drive should be visible - right click on it and see if "Autoplay " comes up
I have an acer aspire 5735 with windows vista home premium. The cd/dvd drawer will no longer open. I can open it using a needle in the little hole however when i put cds in the drawer they will not play...
Try checking in the bios if your cd/dvd is detected there. Try also removing the cd/dvd drive from the laptop and putting back in again. If it still not detected in the bios, have it replaced.
Cant detect the hard drive when installing Windows XP to the laptop, Laptop; Acer Travelmate 4072WLMi - intel Pentium M processor 740 (1.73 GHz, 5533 MHz FSB, 2 MB L2 cache) ...
You need to go into your BIOS and see if the computer is recognizing that you have a hard drive installed. Sometimes the bios forgets and needs to find it prior to the install.
Look in your manual for the procedure to get into your bios....most of the time, it is tapping the delete key right after power up. Be careful not to change any of the settings if you don't know what you are doing or you can make your laptop into an expensive door stop.
Semper Fi,
Z
It wont detect a dvd on my acer aspire 5315 laptop
If your laptop won't detect DVD drive try and check connection first. Turn your laptop upside down and remove three maybe four screw (deepens on laptop) directly over a DVD drive and pull drive out. Blow some compressed air inside of laptop and check for anything abnormal on drive itself. Then put it back in and check if it works. If not it's either bad DVD drive or bad motherboard. Thanks and good luck.
1helpful
My cd/dvd drive is unable to detect any cd/dvd.acer aspire 4520
I do have the same problem, my laptop doesnt detects the DVD writer, checked with the acer support, asked me to check the motherboard and may need to change that.
Acer 4520 cd/dvd driver problem
Try to use another DVD. you told you tried you old DVD from your toshiba. maybe is not compatible.. try in another.. then use your DVD in another laptop if the same from problem.check your board and DVD connection...if this under warranty bring to warranty..
if in Bios also can not detect this is hardware problem...
4answers
Acer aspire 5610z dvd drive
try shutdown the laptop and then boot it, on the booting process go to the bios setup menu check if the dvd drives is enable or detecting on the on.
Try removing the dvd drive with the laptop off, replace the dvd drive and try to boot it again.
5helpful
2answers
My acer aspire 5315 dvd driver wont work
my dvd wonT work when i put cd in it it give a noise and dont deTecT cd or dvd
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
