This is becoming a common problem. Let's see if we can save you $150!!
If your CD-ROM or DVD-ROM Drive Appears To Be Missing then
you will need to manually edit your registry.
Follow the
instruction below.
Click Start Menu. In the Search box, type regedit, and then click OK.
A Registry Editor window will open up.
1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
2. Expand SYSTEM, and then expand CurrentControlSet.
3. Expand Control, and then expand Class.
4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
6. On the Edit menu, click Delete.
7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:
Are you sure you want to delete this value?
The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry
5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak.
7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:
The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
8. Exit Registry Editor.
Step 4: Restart the computer.
This should resolve the problem and there is no easy fix unless you factory restore or reinstall the operating system.
Good luck and please let me know if there is anymore advice that you need.
WHAT do you do if there is no UPPERFILTERS ?
WHAT DO you do if there is no lowerfilters or lowerfilter.bak ?
any suggestion ?
Thank you for your input on my Dell VOSTRO DVD Drive problem.
Unfortunately it didn't solve the recognition problem.
I followed your drections (very precise ones, thank you). I quickly found and deleted the Upper Filters registry entry on the "10318" registry subkey.
The LowerFilters entry was not present (on that same "10318" class).
I powered down and restarted the laptop but it still did not recognize the DVD Drive.
Any other suggestions B/4 I reinstall VISTA?
. Thanks again for your assistance
