Question about Kenwood Dishwashers
Kenwood KDW12ST3a E3 error replaced heater and thermostat still get E3 error
4 Suggested Answers
SOURCE: kenwood dishwasher kdw12st3a error code
in the manual I have for this machine model E3 means: Longer heating time but not reaching requied temperature. The possible causes: malfunction of temperature sensor or of heating element
Posted on Aug 12, 2008
SOURCE: kenwood dishwasher kdw12st3a user guide
GO TO PARTMASTER http://www.partmaster.co.uk/cgi-bin/home.pl
SCROLL DOWN TO BOTTOM LEFT AND USE INSTRUCTION MANUAL DOWNLOAD
AND ITS FREE.
Posted on Apr 25, 2009
  • 16 Answers
SOURCE: fitting a heating element to a Kenwood dishwasher
E3 usually means the heater element has failed. From the title of tyhe post it seems you know that already.
Posted on Jan 24, 2010
E3 error on LIfesmart heater
Even after replacing thermostat and motherboard offered from company, my heater would trigger e3 error code and shut off. After several (maybe 100!) different attempts to plug in and operate, here is what worked for me!
Depress the power button on the heater while plugging in to wall circuit. Continuously depress power button. It will run through a test cycle and attempt to start. Keep depressing the power button as the heater tries to start, then shuts down with e3 error. While the power button is still depressed, unplug the unit from the wall. When I plug back in the wall the E3 error is gone. Good luck
Nov 03, 2012 | Lifesmart DYNAMIC 1000 to 1100 Square Foot...
Kenwood KDW 243A Dishwasher has an E3 fault and will not wash the dishes, can you tell me what is causing this please? Thank you
The error (E3) relates to the water heating but not reaching the required temperature. This can be due to a couple of things generally. The sensor which detects the water temperature can be faulty or the heater element itself is faulty and not heating the water to a high enough temperature. I think it's needing to be replaced.
Check to see if there is a thermostat screwed up into the underside of the tub on the rear right side. If there is, test the thermostat to see if it's open circuit, if it is you'll need to change it.
Jun 12, 2011 | Kenwood KDW243A Builtin Dishwasher
Hi - have a kenwood KDW125L3A and is showing error E3 - help please. Ricardo
E3 is a temperature error. There are two thermostats,90 degrees and 78 degrees. This requires removal of the ride side of themachine to access. The other signal for the E3 error is the heating elementitself. If the water isn't heating at all, either the element or the 90 degreestat is faulty. You can change both and none of it is difficult to change for amoderately competent.
Jun 03, 2011 | Kenwood Dishwashers
How do I deal with an E3 error code?
E3 error code means the water is not being heated to the required temperature in the machine.
This may be either a defective heating element or faulty thermostat.
Dec 28, 2010 | Kenwood Dishwashers
My kenwood KDW12SL3A dishwasher dysplays E3 error every time I use it. dishes don't get cleaned properly. Can I fix it myself? if not how much will it cost me to get it fixed by a professional? thank you
Hi
E3 error code neans the water is not being heated to the required temperature in the machine.
It is unlikely you can fix this yourself.
Depending on what is wrong it might cost you around $150
Dec 20, 2010 | Kenwood Dishwashers
Fitting a heating element to a Kenwood dishwasher
Jun 27, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Kenwood dishwasher kdw12st3a error code e3, what does this mean ?
Aug 01, 2008 | Dishwashers
I HAVE A KENWOOD KDW12ST3A DISHWASHER AND IT HAS THE E4 ERROR CODE THEY DID NOT GIVE ME A MANUAL WITH IT CAN YOU HELP
i hav a kenwood kdw12st3a and the e4 code came up and it said in the manual it had overfilled but it did'nt tell you how too fix it can you help
Apr 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
455 people viewed this question
Top Kenwood Dishwashers Experts
Oloyede Monsuru
fadirahal
Level 1 Expert
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
