Question about Philips GoGear SA3125/37 MP3 Player
Battery wont charge when plugged into computer. It is connected because I can loan/unload music but battery is dead.
  • 68 Answers
Replace batery from serrvice center
Posted on Jul 20, 2010
My sansa when its connected to my computer comes on works syncs and everything so as i disconnect it from my computer it' s dead and wont turn on
Three possibilities;
1) You have a dead battery because the battery is no good.
2) You have a dead battery because your Sansa is no longer charging the battery.
3) You have a dead battery because you didn't leave your Sansa tethered long enough to charge it up.
When you have the Sansa c250 tethered to the computer, you should see a tiny yellow lightning bolt flashing, and a battery icon that shows the amount of charge on the battery.
If you see the lightning bolt, but the battery does not charge after being tethered to a working computer or charger for 24 hours, you may need a new battery. You can get one on Amazon.com. Here's a link:
http://www.amazon.com/HQRP-Replacement-Battery-Universal-Protector/dp/B001NZ981S
If you see the lightning bolt, and the battery charges after 24 hours, AND your player works when unplugged--Problem solved! You just need to let it charge for a longer time.
If you do not see the lightning bolt when the player is tethered, and the battery indicator shows "empty," It's likely that the internal plug to your Sansa c250 has broken. Your Sansa is no longer able to charge the battery.
If you happen to be an electrical engineer, or otherwise have a shop full of electronics equipment (including signal injector, volt-ohm meter, needle-tip soldering iron, and stereo magnifying goggles with work lamps) you may be able to fix it yourself. Otherwise, forget it-- your Sansa is dead.
If it's still under warranty, try to get it replaced. Failing that, it's time to get a new MP3 player.
Hope that helps! Please post a message to let others know what happened to your Sansa player.
Nov 22, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
The mp3 player wont charge. plug into computer and it shows charging but as soon as it is disconnected it shuts off and wont turn on.
Some mp3's don't expressly charge on the computer, that why when you connect it, the computer only sees it as a flash but is not actually charging it all this while and the battery is completely down. So try and get an external charger for it, the battery may be completely dead.Or probably you need to change the battery. Hope that puts a smile on your face.
Feb 04, 2010 | Samsung YP-K5 MP3 Player
My battery went dead. plugged it in and wont do anything
mine is doing the same. i have a SanDisk 4GB mp3 video player & mines went dead too and it will show it charging for a few seconds then it will just stop & it will just show the connected sign. try holding the power button for 15 to 20 seconds. maybe that'll work
Sep 03, 2009 | Philips Audio Players & Recorders
Nextar MA715 MP3 player wont take a charge.
Best first bet is dead battery. If it is a special battery then do the costings for the repair as it may be cheaper to replace the player.
Jun 13, 2017 | Nextar MA7151B MP3 Player
New base mp3 digital music player gk915
Have charged for the recommended time. Battery shows as full. Can only turn mp3 on when its connected to usb. When not connected to usb it wont turn on.
Jun 28, 2008 | Audio Players & Recorders
My 30G 5th Generation pod is totally dead and will not charge even with a new battery
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer is not set to sleep, standby, or hibernate.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    If the Apple logo does not appear or the iPod is not seen in iTunes, the iPod should be serviced.
Nov 22, 2007 | Apple iPod MA446LL/A MP3 Player
I can't turn on my Sansa e250!! Help!
Check the battery connection(s) in the back. Remove the 4 screws, remove the battery an re-connect it. Charge the device for a few hours. Best of Luck.
Oct 05, 2007 | SanDisk Sansa e250 MP3 Player
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
V3 Razr is dead, wont charge
take it to a local cell phone dealer and see what they say. most likley bad charger or bad connections.
Jul 08, 2007 | Motorola Mobility RAZR V3
Philips GoGear SA3125/37 MP3 Player Logo
197 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
