Question about Foxconn C51XEM2AA-8EKRS2H (0683562100229) Motherboard
FOXCONN C51XEM2AA and getting LED error 2d
I have a FOXCONN C51XEM2AA and getting LED error code 2d
4 Suggested Answers
Nickstar19
  • 417 Answers
SOURCE: startup fault
Software Error Or Corrupted windows File files
Posted on Jul 15, 2008
  • 147 Answers
SOURCE: need table of LED error codes on Foxconn mobo
here you have a link to foxcon website to take his manual, there you can see about your problem
Posted on Apr 10, 2009
  • 192 Answers
SOURCE: No Power!
So, have you checked first with a multimeter to see if the wall outlet is getting power. Next, check the power cord.
Have you also checked the power supply with another system. Just make sure you didn't hook up to many devices to the power supply. If you did, then it wouldn't power up.
If you are getting power from the power supply in another unit, then disconnect any add-on cards, optical drives, floppy drives, etc. and just boot from your hard drive.
If you still don't get anything, check the CMOS battery to make sure that it is at 3 V. Some motherboards won't boot if that battery is to weak.
Also, what type of thermal grease are you using. Is it the white paste or phase change material or arctic silver.
The white paste dries up and doesn't cool effectively. Also, how thick did you apply the paste or phase change material. The thinner the coat the better.
What type of RAM are you using? Is it compatible and did you reseat it as well as the CPU.
Check the RAM in another computer as well as the CPU. If the RAM and CPU is good, then the motherboard you got is defective and needs to be replaced.
If you don't get anything at this point, then eitherthe motherboard is at fault.
If you don't get anything at this pointyour power cord is getting power.
Posted on Sep 01, 2009
Cannot format a sata drive completely, i have installed a new master hdd which is 500GB, however when formatting I can only see 128GB
Check drive for partitions. Also, you can use a program such as Seagate DiskWizard to format and setup for loading. That program is available from Seagate's web site.
Jun 17, 2010 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Power failure when i press power button it doesn'tt happen any thing
When you press the power button and nothing - I mean absolutely nothing - happens, and if your indicator panel is showing that it is plugged in, then it's a dead power button board. Period.
This is a common problem with the 1905 series.
Sep 07, 2009 | Toshiba Satellite 1905-S301 Notebook
Alienware c51xem2aa out the box wont turn on
If there was a spark and it smelled, something probably burned through. If I were you, I'd send it back to Alienware and request a new one. Even if you could fix this now, the risk of it breaking again in the future is much bigger. I hope you'll get your new PC fast, Yannick.
Jun 07, 2009 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Need table of LED error codes on Foxconn mobo
Apr 10, 2009 | Foxconn (865G7MC-ES) Motherboard
Repeated boot
I supposed you are using windows xp, put the Win XP cd in your cd drive and start your computer
boot on the cd drive, wait until the winxp finishes its copying
When asked if your want to install winxp or repair [R] choose repair by pressing R
wait till the command line and type: chkdsk /r
wiat until it finishes, it may take about 20 to 30 minutes..
reboot your pc
Oct 25, 2008 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Will not power down, bios code 7F,
You need to check the mobo front panel PWR and RESETconnections as they must be wrong if youve connected them yourself
Aug 27, 2008 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Startup fault
Jul 15, 2008 | Foxconn (945G7MA-8KS2) Motherboard
No POST
I'm going to assume you supplied the proper 8pin 12v connector besides the necessary 24pin, right? Unplug all cables to any internal peripherals, even data cables. Since you're getting random LED errors, I would remove the video card, open up one of those ancient computers to remove a PCI video card, install it on this board and boot to CMOS. I'd also prepare a Memtest86+ boot diskette and check each memory stick individually (that is if you have a PCI video card output). Keep monitoring/logging those LED errors (to note any type of pattern). The onboard MOLEX power connector, used to provide additional power to the PCI-Express slots when using x16 cards in SLI mode, is located between PCI slot 2 and the board's edge, as a last ditch effort, try powering it up when the Single SLI card is installed. Otherwise, you have either a mal-performing power supply (regardless the total wattage), a funky video card or a DOA motherboard. Always need to carry a known good PCI video card, I use a Matrox Millenium. OH... and take a good slug of your favorite liquor. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Foxconn C51XEM2AA-8EKRS2H (0683562100229) Motherboard Logo
253 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
